03-22-2012, 01:53 PM | #1 |
Antenna in windshield
My radio reception is TERRIBLE. Factory antenna wires are in the windshield glass. Not sure if the antenna is the problem or the radio (old Pioneer with digital tuner circa 1993-94 with supertuner).
How long did GM do the radio antenna in glass trick and when they stopped, where did they put the antenna on these trucks (pics would be lovely....)? |
03-22-2012, 02:03 PM | #2 |
Re: Antenna in windshield
I believe they did it on all the squares. As I recal the 70s camaros had them as well. I live in an area with a lot of deep hills and valleys and don't have an issue with reception
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
03-22-2012, 02:46 PM | #3 |
I have great reception with my antenna, could be your radio.
1981 K10 Scottsdale
305 ci | TH350 | NP208 | 60k miles |
03-22-2012, 03:46 PM | #4 |
'68 Pontiac GTO was the first application, and then many applications after that.
Squares had the windshield in the glass through '87 and then those carryover '88 and up R/V trucks got the mast antenna again for the remainder of the run. Antenna was mounted at the rear of the RF fender. So, based on the fact that there are millions of vehicles on the road with a windshield antenna - I bet your radio is the problem. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-22-2012 at 04:04 PM. |
03-22-2012, 04:02 PM | #5 |
You can't beat a window antenna. well you can, but mine is excellent everywhere. i would say it could be the connections. clean them up and see what happens
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e |
03-22-2012, 04:12 PM | #6 |
My 86 C10 has the mast mounted on the RF fender, would that be out of the ordinary then?
Well even with the antenna mast, my old 90's tape deck sounded terrible. I put in a new radio, and much better. I'd say its your ancient stereo |
03-22-2012, 04:28 PM | #7 |
78K & 79C Jimmys
my old Pioneer had settings for the antenna,try looking up for the manual
also some time the plug changed in size make sure it's going in I guess some of mine were done after thought it was weird but 78 pass 79 win 79 drivers 88 pass 89 win sucked, i stuffed one loose in the fender it worked
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-22-2012, 04:36 PM | #8 |
Moderator
I had 2 Pontiacs, an Olds and 4 of these squares with the windshield antenna.
There's a 2-3" snap on pigtail at the bottom center of the windshield that plugs into a coaxial pigtail cable under the dash pad. They work very well unless the pigtails are damaged or unplugged. Windshield button pigtail Behind dash cable |
03-22-2012, 06:16 PM | #9 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-22-2012, 08:27 PM | #10 |
I had the same problem, I guess the previous owner did also because the truck, (87) came with a fender mounted antenna still in the package. But I ended up changing the stereo and now the glass antenna works perfectly.
03-22-2012, 09:36 PM | #11 |
I always wondered, why did they stopped using them? Other than the fact that there's nowhere to stick an antenna ball...
1977 GMC Sierra Grande |
03-22-2012, 10:15 PM | #12 | |
I know the pieces fit
03-22-2012, 10:28 PM | #13 |
My radio came in pretty bad.. When I was putting it back together I used new parts.. the part that plugs into the glass was a little beat up... radio comes in good now..
I got a new deck too.. so not 100% which fixed my problem..
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy? Last edited by vegas80step; 03-23-2012 at 12:39 AM. |
03-22-2012, 10:29 PM | #14 |
Cruzin
i have two 85 truck and 75 nova with it and love them just had to replace the lead going to the radio in my nova for better performance.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
03-22-2012, 10:57 PM | #15 |
my '87 windshield antenna gets great reception.
My '89 fender mount gets horrible reception. I am guessing its the radio.
1995 GMC 4x4 1/2 ton 1999 Jeep Wrangler w/ 33's 68 camaro 350/350 1987 Chevy 3/4 ton 4x4 Suzuki DRZ 400s Dual Sport 1971 chevy long bed 2x4 194? Dodge 2.5 ton 1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455 1989 Chevy V30 crewcab dually 454/TH400 |
03-22-2012, 11:41 PM | #16 |
My 83 C20 beater has good reception with the aftermarket windshield with integral antenna and a new antenna connector (from Classic Parts, IIRC).
I installed a $100 Alpine head unit from Crutchfield and it continues to sound great. I can get powerful Phoenix AM stations in Tuscon (~ 100-150 miles away)-not clear as Tucson stations but still very good reception. So Keith, why did GM stop using the windshield antenna? This was one of the GM engineering competitive advantages. Were they trying to be more like the Japanese and other 2/3 of the big 3? |
03-23-2012, 12:06 AM | #17 |
In the Forgotten far North.
I pulled the windshield out of my old crew cab before scrapping it and it now lives in my '90 suburban. I bought a "Y" adaptor for the antenna lead and I now have 2 antenna's hooked up to my stereo.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
03-23-2012, 12:31 AM | #18 |
03-23-2012, 02:39 AM | #19 |
My '73 has a mast antenna and the windshield antenna...I don't know why. Somebody stole the stereo....
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's. You can set my truck on fire and roll it down a hill, and I still wouldn't trade it for a Coupe de Ville. |
03-23-2012, 07:23 AM | #20 |
Bought the 76 custom deluxe with a fender antenna. This was in 87 so it may have been" customized" before that.
03-23-2012, 10:52 AM | #21 |
Interesting. I too would like to know why GM stopped putting them in the WS. My 94 Honda Accord has the antenna in the back glass, and the 95-97 of the same body style went on the back fender.
I'll pull the head unit and see if I can clean up the connections. I have the stock AM/FM radio around here somewhere (dad never throws anything away) so I might even put that back in. I have an FM modulated Ipod hook up so I could still use an Ipod with the stock head unit. |
03-23-2012, 11:56 AM | #22 |
I'm not sure we've actually "stopped" - as you mention, on some SUVs (Suburban/Tahoe/Cadillac) we put the antenna in the quarter glass today.
I think its a matter of "trends" or fashion - which come and go. K
