03-23-2012, 12:01 AM | #1 |
Brush & Roller Paint Job?
Funds are tight so I've been pondering the idea of using a painters roller and brush to paint my truck! I know, never in a million years would I consider something like that but I came across a site that makes it look possible! What do you think?
Check it out! http://rolledon.forummotion.com/f2-projects |
03-23-2012, 12:19 AM | #2 |
Re: Brush & Roller Paint Job?
Go for it..i bought a cheap spray gun jus so i can do mine with tha time permits..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
03-23-2012, 12:20 AM | #3 |
Not this again..
Rust is better than rice. |
03-23-2012, 12:29 AM | #4 |
Yes..this again & if you don't have anything helpfull for to OP..the lil red X in tha top right will assist you in leaving...thanks for playin..
03-23-2012, 03:04 AM | #5 |
i have heard of this and even seen a guy rattle can and get this close. I havent done it but i think anything is possible if you ve got the time to sand and buff. But i got to think it is a lot of sanding.
03-23-2012, 07:22 AM | #6 |
78K & 79C Jimmys
i didn't sleep at a holiday inn last night
but i did roll and brush my truck last year when some others were it was suggested at the time to thin it out,quite a bit this was my 4-5 th time rolling a paint job aside from somebody keyed the drivers door,it still looks great I used gloss tremclad starts about here http://67-72chevytrucks.com/vboard/s...=421767&page=7 and Kikkegek did his as well but he thinned it and it looks much smoother http://67-72chevytrucks.com/vboard/s...=415333&page=3
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-23-2012, 08:33 AM | #7 |
I have seen cars with Rustoleum (or Tremclad) roller jobs that looked okay, but what happens if you decide to paint it for real later?
The solvents in most primer / sealers will wrinkle or lift uncatalyzed enamel. |
03-23-2012, 10:06 AM | #8 |
78K & 79C Jimmys
you would have to strip it
the ones I've done, winter cars,camping, bush trucks 87 flat black bout 3 or 4 coats bird pic bout 5-6 years later
03-23-2012, 10:11 AM | #9 |
78K & 79C Jimmys
or fun
03-23-2012, 10:20 AM | #10 |
I did my truck this way last fall. Rolled on Rustoleum unthinned, because I wasn't really looking for it to self-level that much, my bodywork was already pretty rusty and rough. I sanded the really rusty spots, brushed on some rust converter, then a coat or rustoleum primer, then the paint direct out of the can. The finish has a small amount of 'texture' as I just left it as the roller, didn't try to smooth it after with the foam brush as some have done.
My truck is rusting away, and it's not going to survive long enough that I will ever be painting it with proper automotive paint. But this way I was able to hide a fair amount of the rust from view, and hopefully buy enough time until it will need to be retired. I have some pics linked in the "Brown Trucks" thread of the end result. It has held up nicely agains the Minnesota winter, although this year that wasn't as sever as normal. But I really do want to hit it with some car poilsh or wax or something, didn't get a chance to do that last fall before the cold hit. I was disappointed only in the actual color, on the can it looked to be a much better match for my original dark brown. it ended up MUCH lighter once it dried. But I really only wanted to get the truck to match color-wise, as I had fenders in primer, a door from a red truck, and a nasty tailgate from the salvage yard, it looked like a real mutt.
TomS. '98 S-10 Blazer 4dr 4wd - 4.3, AT, stock & '85 K-10 w/ 305, 700r4, np208, and RUST! SOLD Dec 2014 |
03-23-2012, 02:20 PM | #11 |
Just here to tinker
May I suggest rattle can? I have gotten away with many a rattle can jobs. In fact, the roof of my pickup in the photos below is rattle canned. Two cans of home depot paint for $16 total, I think.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
03-23-2012, 03:30 PM | #12 |
I did. Used Rustoleum and rolled it on. The red paint was just getting too bad...
before after:
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
03-23-2012, 03:54 PM | #13 |
If the Rustoleum has cared you usually don't run in to that problem
03-24-2012, 12:04 AM | #14 |
Snowfighter
i did this on a hood to see what all the fuss was about. yes if you ever want to put automotive paint you'll have to strip it all off. prep work is the key as it is with any paint job. and yes there's quite a bit of sanding involved. here's a couple of pictures of my rolled on paint job.
'72 Chevy suburban 2wd-sold '05 chevy trailblazer '02 Jeep Wrangler '03 Ford Superduty crew cab 4x4 '84 chevy c30 crew cab dually |
03-24-2012, 02:15 PM | #15 |
well i did not have to strip it all off but it was on there over a year sanded it with 220 then 400 and paint
03-24-2012, 07:00 PM | #16 | |
