Old 03-23-2012, 12:44 AM   #1
rayfinseats
Why doesn't anyone?
Why doesn't anyone make a transfer case with a lower high gear? They are all 1:1 correct? It seems to me it would be easier than changing both gear sets in a 4x4. Anyone? anyone?
Atlas RATIOS:
Low Range: 2.0:1 or 3.0:1 or 3.8:1 or 4.3:1 or 5.0:1
High Range 1:1
rayfinseats is offline   Reply With Quote
Old 03-23-2012, 01:29 AM   #2
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: Why doesn't anyone?
I believe it has to do with the room needed for another reduction unit. When in high range the input and output can be directly driven together and in low range gear reduction does its job. To have two ratios other than 1:1 the case would be about twice as long; much like guys do with double cases on hardcore trucks.
You can also run a torque happy motor with a granny first! That's how I run 3.73s and 35s. (was 3.55 and 35s on my donor). I love my Cummins.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 03-24-2012, 11:28 AM   #3
rayfinseats
That makes sense.
Old 03-24-2012, 05:17 PM   #4
In most transfer cases low is 2:1. Even lower in some. If you have a truck 4spd 1st gear is 2:1,so when in 1st and low you have 4:1 reduction. I think things are the way they are because it's worked just fine that way for 50 years or more. People never tried to drive where you should get out and climb until more recently. For those people they can modify their rigs to suit their desires. I don't expect any auto manufacturer would build their product to rock crawl.
Old 03-24-2012, 09:29 PM   #5
Mr. 250r
Mr. 250r's Avatar
I put my 04t cummins in 4lo 1st just to see how it was compared to my 01 and man lol talk about some pulling power but not at all driveable I would like to have a 24v 6spd suburban but that'll probably never happen as far as people making them if you want an aftermarket setup there's a company that builds new cases to make the 205 lower since its weak point is basically its low I think they're called low max but I could be wrong
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC LB DRW - Sold
2003 1500 Silverado - Selling
2004 Ram 3500 5.9 H.O NV56 CC LB DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LB SRW
Mr. 250r is offline   Reply With Quote
Old 03-25-2012, 12:26 AM   #6
Zoomad75
K5Camper
Zoomad75's Avatar
To the average wheeling public, 2:1 low range in a 205 is just fine. The later 208 and 241's have a better ratio but it's still more than enough for the average weekend wheeler. You don't have to have a major low range for trail running. You can get a 3 speed stak or 4 speed atlas if you want to go nuts. But if you aren't doing some major rock crawling with one of those you just spent a ton and aren't even using it.
Even though my K5 has the 2:1 205, I haven't been limited by it. If I need more gear I dump the trans into Granny and plod around at a snails pace.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 04-06-2012, 11:35 AM   #7
hereinmissoula
totally get what your saying and makes total sense!! 2:1 low .78:1 high or what ever..
cool
never seen it but would check it out as i have 4.57's in my 68 and only on 33's
don't go very fast lol
hereinmissoula is offline   Reply With Quote
Old 04-06-2012, 11:47 AM   #8
Dunenutt
Newbee
Dunenutt's Avatar
They make a kit. 203/205 doubler...
http://offroaddesign.com/catalog/doubler.htm
Dunenutt is offline   Reply With Quote
Old 04-06-2012, 11:44 PM   #9
rayfinseats
cool
Ya I think it makes sense. It would be easier than changing 2 perfectly good rearends or gears. Technically difficult though I think.
About 10 years ago I sold my 79 chevy 3/4 ton 350/th400. The body was junk. Wish I could have afforded to keep it.
Old 04-09-2012, 10:57 PM   #10
Prerunner1982
Prerunner1982's Avatar
Or an SM420/SM465 with a 7.05 and 6.58 first gear respectively.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 04-13-2012, 02:13 AM   #11
andrewmp6
This might help http://coloradok5.com/forums/showthread.php?t=46347
andrewmp6 is offline   Reply With Quote
Old 04-14-2012, 02:59 AM   #12
rayfinseats
Seems hereinmissoula is the only one that even read the question. No offense.
Old 04-14-2012, 03:48 PM   #13
lowrollin70gmc
Too many projects
I read it; to have a high other than 1:1 it would take more room, as the gear reduction/overdrive unit takes more space than the direct coupling used as the 1:1. Also, overdrive gears tend to be weaker than a 1:1 and with play time in a 4x4 it would be easy to frag the gears.
Regearing isn't that bad, I'm in the middle of doing my buddies D60/14FF from 3.73s to 4.56s (other direction than you're headed). He would've easily swapped complete axles with somebody that had the 4.56s and wanted 3.73s but we couldn't find someone to do it with.
Andrew
Old 04-16-2012, 07:38 PM   #14
Altec
Getcha Pull
Altec's Avatar
Just to point out, gear reduction pre-axle is a lot harder on on U-joints, drive shafts, and axles then using the axle for reduction. The less of it you have to have, the better.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 04-17-2012, 05:59 PM   #15
wilkin250r
wilkin250r's Avatar
I think all the reasons have been posted.
Even though Jeeps are probably the most popular to crawl, at least 90% of them go unmodified, and other makes/models are even more so. Like special-K posted, no auto manufacturer is going to build their product to crawl. For them, designing a case with an overdrive high gear is MUCH more complex and expensive than just gearing both axles. You're looking at a re-gearing cost, they're looking at it as an initial cost. Whether they gear with 3.55 or 4.10 it's all the same cost to them.
Likewise, direct coupling is going to be easiest, cheapest, shortest, and most reliable. I can't imagine any manufacturer on earth incurring additional cost up front, as well as sacrificing reliability, just to make regearing easier and cheaper for the 5% of the population that does it.
That still leaves open the question of the aftermarket manufacturers like Atlas, Klune, ect ect. While nobody likes to spend more money than they have to, the aftermarket manufacturers aren't targeted at the "cost-conscious" crowd. The people that buy their products want strength and reliability, and size plays a small factor as well. Again, direct drive is going to be cheapest, shortest, and strongest. And not just for the transfer case itself, as Altec pointed out, you would be adding additional stress everywhere down the line. Imagine the stresses on your U-joints if your driveshaft was spinning 4.56 times SLOWER than your axles, rather than the other way around.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 04-17-2012, 10:16 PM   #16
MadManAndrew
No, they did. You just didn't understand thier answer. And plus, that wouldn't make any sense. Why wouldn't you just make the transmission gear ratios shorter in the first place?
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 04-17-2012, 10:30 PM   #17
Redcap
Exactly.
Redcap is offline   Reply With Quote
Old 04-18-2012, 01:33 PM   #18
wilkin250r
wilkin250r's Avatar
The only way I could see that being reasonable is if you have the ability to change and adjust the ratio in the transfer case, so you could pick (from a limited selection of course) the drive ratio that would work for you. That way, you're only changing one set of gears in the transfer case, rather than two sets of gears in the axles.
