Old 03-23-2012, 01:51 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
LQ4 Short Block...Intake???
I found a low milage LQ4 short block for about $650 that I was thinking of picking up , the guy aslo has some L92 heads for sale for $500 or so that I was thinking about. Have a couple questions
Intake - How good is the edelbrock Pro-Flow? Looks killer but does it perform? What type of Throttle body and what size would work??
If I go with an aftermarket intake I guess I would just get an aftermarket ECM?
Man I have a lot of catching up to do with these motors!!!!
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 03-23-2012, 03:35 PM   #2
noonzor
Re: LQ4 Short Block...Intake???
theres huge potential with the stock ecu's with the right tune, ill be running the stock ecu for my eng/trans and getting a local tuner to set it all up for me. the pro-flo is getting good reviews especially with the turbo crowds (holley has a similar unit thats more expensive and better looking imho, but not for cathedral heads yet), if your planning na i would stick with an ls3 manifold or the l76 on the the l92 heads or if youve got the dollars the fast 102 is always an option. if you take the l92 heads remember they are rect. port not cathedral. tb choice will come into which intake you decide on, lots of stock ported tb's being run with good success.
id head over to ls1tech and do some reading there, if your in need of ls information thats the place to ask.
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 03-23-2012, 04:27 PM   #3
6600DURAMAX
Do the L92 heads make more HP than the LS1 Cathedral type?
Old 03-23-2012, 05:24 PM   #4
noonzor
l92's will outflow a stock ls1 head yes. but there are some great flowing cathedral heads out there as well. its all going to come down to your goals and what your want to use on your motor. is cathedral better or is rect better? im not touching that one.
Old 03-23-2012, 08:10 PM   #5
6600DURAMAX
Goal would be a dead reliable motor with about 450HP that I couild drive anywhere. This is my first time down the LS route so I have a ton to learn
Old 03-23-2012, 10:40 PM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
Lq4 w/ 799/243 heads to bump compression, long tube headers, and a mid range cam will get you to 450hp cheaply, easily, and reliably. Use stock PCM for cash savings- aftermarket if you wanna spend money. The pro-flo is an upper rpm intake- it will likely kill a street motor down low. L92s are a good choice, but will need a high lift cam to take advantage of the flow capabilities. They also require specific intake and rocker arms, but not a big deal if you're starting from scratch...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-25-2012, 11:59 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
pro-flow is cool, imo if you are gonna go l92 heads the lsxr/t intake is the tits, but super pricey.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
