Old 03-23-2012, 04:27 PM   #1
Integradude71
Emergency brake parts
Hi guys:
I'm new to the forum, so I apologize if this question has been posted elsewhere, but I have looked and haven't found it. My 71 SWB has been missing the e-brake since I got it. That means missing everything from the pedal to the cable to the parts in the brake drum.
I've since gotten everything I need to install an e-brake except those drum parts. I'm not even sure what to call them, but does anyone know where I can get them? I'll even buy a used drum that has them if necessary. These parts may be common to a bunch of GM products from the time that have the same diameter brake drum. These are not parts that wear out and are only needed because they were discarded by a careless mechanic too lazy to remove them from the old brake shoes and put them on the new ones. They should be cheap but are not available from the usual suspects, like LMC Truck and the like. Appreciate any advice.
Integradude71 is offline   Reply With Quote
Old 03-23-2012, 05:37 PM   #2
nightmare
nightmare's Avatar
Re: Emergency brake parts
go to a junk yard and look for pretty much any GM truck '71-'87. those parts should be the same all through those years.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 03-26-2012, 12:12 PM   #3
Integradude71
Nightmare:
Thanks for the quick response. Do you know what those parts are actually called? Are they parking brake brackets?
Old 03-26-2012, 12:26 PM   #4
old Chevy guy
old Chevy guy's Avatar
You need all the stuff in the drum? The lever and the two push bars? I have that stuff,tried to sell it to a guy on the parts forum that had a WTB add but he never got back to me. $25 shipped send me a pm and we can set something up if you are interested.
old Chevy guy is offline   Reply With Quote
Old 03-26-2012, 06:32 PM   #5
brans72
if a 83 ebrake pedal assembly will work pm me got one in garage taking space up. Brandon
brans72 is offline   Reply With Quote
