Old 03-23-2012, 07:17 PM   #1
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Coil is burnt up...AGAIN!!!----TBI
I have a 1987 3/4, 350 mtr, chevy truck and my coil keeps burning out. Its all burned on top and has left me stranded twice. Any ideas?? It will spin over. Im thinking module or distubutor related??? Help!!
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 03-23-2012, 07:31 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Coil is burnt up...AGAIN!!!----TBI
years back i had a similar issue and we ended up replacing the whole distributor.. there was an issue that the shaft had too much play in it or something.. its been a while and the old mempry isnt as good as it used to be
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-23-2012, 08:11 PM   #3
rfmaster
rfmaster's Avatar
Check the tachometer test lead (if you have one) and make sure it is not grounding inadvertently.
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 03-23-2012, 09:14 PM   #4
tazman87
tazman87's Avatar
my old man had the same problem two weeks ago....his case....stock dist, MSD cap MSD coil....= bad combo
tazman87 is offline   Reply With Quote
Old 03-23-2012, 10:25 PM   #5
texassquarebodies
Truck Nut
I will probably just change the whole thing. I have a few. I have had to pull it home the last two times I drove it, both with a trailer behind it.
Tony Kee
Texas Square Bodies
Old 03-23-2012, 10:36 PM   #6
rs72z
rs72z's Avatar
Tony,
Have you replaced the plug wires or checked resistance?
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 03-23-2012, 10:40 PM   #7
esbstuff
May check for ground on coil... make sure all your mounting points are clean, so they will ground well. Also make sure the coil is tight in its holder.
esbstuff is offline   Reply With Quote
Old 03-23-2012, 11:24 PM   #8
texassquarebodies
Truck Nut
The plug wires are newish and i dont know how to check the resistance
Tony Kee
Texas Square Bodies
Old 03-24-2012, 12:06 AM   #9
andrewmp6
How do you have the coil mounted?If its on a angle and one of the poles on it is straight up a air bubble can forum there and cause it to burn out.
andrewmp6 is offline   Reply With Quote
Old 03-24-2012, 04:21 AM   #10
grayharville
^^who I am^^ what I say>
grayharville's Avatar
Try hitting it with a hammer.
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 03-24-2012, 04:36 AM   #11
bayou boy
bayou boy's Avatar
yeah Hammer works for me
all i know is that its going to be orange
bayou boy is offline   Reply With Quote
Old 03-27-2012, 01:41 AM   #12
texassquarebodies
Truck Nut
Well, My 72 yo. Dad came down to the shop at 10;30 pm, which is very unusual. I decided to replace the whole distibutor and the coil with one I knew was good after Autozone said a module would be $42. I already had a new cap and rotor sittn in my shop.
I coulnd't get everything lined up right. He did has dad magic and got it running again!!! Made my day. We had it goin in about 45 minutes. Gotta get a timing light now. Starts and runs great. Just gotta do a test drive.
thanks guys.....except gray harville.
Tony Kee
Texas Square Bodies
Last edited by texassquarebodies; 03-27-2012 at 01:43 AM. Reason: Gray.....I got a big block chevy
Old 03-27-2012, 12:28 PM   #13
grayharville
You're welcome.
East Tx Squares
Old 03-27-2012, 01:45 PM   #14
ramz
ramz's Avatar
under the coil is a part (sorry cant remember off hand) that has a spring on it and it sits under the coil. I forgot that once and it burnt up my coil.
ramz is offline   Reply With Quote
