Old 03-23-2012, 11:17 PM   #1
Wrecked1982
Wrecked1982's Avatar
repaired dash
i showed some pic in another treat but its done now so here its is.
1-clean the cracks
2-sand and apply fiberglass
3-sand and apply body filler
4-sand and prime
5-sand and shoot dupli color ratle can bed liner
6-paint with flat black interior trim to finish it up
Wrecked1982 is offline   Reply With Quote
Old 03-23-2012, 11:19 PM   #2
Wrecked1982
Re: repaired dash
Old 03-24-2012, 12:04 AM   #3
1425956
1425956's Avatar
Re: repaired dash
Very nice. What type of sander did you use on the body filler? D/A, inline, 8"? Or good ole elbow grease???
Jeremy
I have done so much, for so long, with so little, I can do anything with nothing!
1984 GMC Sierra Classic-1/2 ton-SWB (R.I.P.)
1986 GMC Suburban 3/4 ton 4x4
2014 GMC Sierra LTZ Z-71 Crew SWB
1425956 is offline   Reply With Quote
Old 03-24-2012, 12:55 AM   #4
Pop's C-10
Pop's C-10's Avatar
Re: repaired dash
wow..that was rough & came out killer...nice work..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 03-24-2012, 08:55 AM   #5
Car'n'Guitars
Car'n'Guitars's Avatar
Re: repaired dash
Did you remove the vinyl to do this?
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 03-24-2012, 09:44 AM   #6
Wrecked1982
Re: repaired dash
thank guy!!!
we sanded it first with ... a.. dont know what its called but its a steel band with holes that takes of big chunk of body filler , the things wifes use to grind cheese to make a lasagna, then we sanded it 180grit with an electric body-not wood sander, then block sanded 180 grit. finish by hand with 400 grit paper. i only removed the vinyl where the crack were the make a concave cavity.
Old 03-24-2012, 09:51 AM   #7
Telecasterjoey
Re: repaired dash
I know it's a pain in the ass but can you list specifically all the materials you used? I'm gonna attempt this lol
Looks amazing by the way!
Telecasterjoey is offline   Reply With Quote
Old 03-24-2012, 10:04 AM   #8
Wrecked1982
Re: repaired dash
i used , fiber glass kit, comes in a box with the fiber and a resin square can, body filler is the X one. by far the best body filler we ever worked with. then normal primer but sprayed with a gun, then its dupli color ratle can black bed liner kit and on top of that its 2 coats of flat black interior plastic trim paint.
also sprayed by gun.
now for the primer and trim paint they were left overs from previous job and i dont to the mix and shoot stuff so i dont know what brand they were but you mostly get the idea.
at first we werent suposse to put trim paint but the bed liner spited big chunks and almost made a mess.once dry when you moved your hand on it ,it left some black film on your figers and even dry they were some spot where it kinda react to the body filler making it look like there was wet and dry spot.
Old 03-24-2012, 12:52 PM   #9
bigsj
bigsj's Avatar
Re: repaired dash
Dash turned out very nice great job.
bigsj is offline   Reply With Quote
Old 03-24-2012, 11:07 PM   #10
1425956
1425956's Avatar
Re: repaired dash
I know fiber glass is flexible, but what about that X Grip body filler? I just redid my dash using the Great Stuff foam from Wally World. But it still needs a small amount of something to smooth it all out so I can prime and paint. It was a hell of a lot cheaper than fiberglass (maybe not as durable) and filled the gaps just fine. I know these dashes have to flex slightly and will certainly flex upon install. I was surprised at how sand-able the foam was after it dried over night. Your dash looks great though and I hope mine turns out that good.
Jeremy
Old 03-25-2012, 12:28 AM   #11
vegas80step
vegas80step's Avatar
Re: repaired dash
came out great...
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy?
vegas80step is offline   Reply With Quote
Old 03-25-2012, 06:14 AM   #12
kylep
kylep's Avatar
Re: repaired dash
that is sharp looking, i did not know you could do that. Thanks for putting this up!
kylep is offline   Reply With Quote
Old 03-25-2012, 09:43 AM   #13
Wrecked1982
Re: repaired dash
you are all welcome
Old 03-25-2012, 05:41 PM   #14
Smoke_Dog
Smoke_Dog's Avatar
Location: Hickory, NC native, but stuck in Valdosta, Ga
Re: repaired dash
LOOKS Good! I'll send U mine's !
Smoke_Dog is offline   Reply With Quote
Old 03-25-2012, 09:07 PM   #15
Wrecked1982
Re: repaired dash
lol no problema ill do them
