03-24-2012, 01:58 AM | #1 |
A/C question
Did burbs come with rear a/c only? My option sheet says air cond overhead system and I have the ac lines to the rear ceiling but my dash doesn't have the a/c vents and my controls don't have anything labeled for a/c control. I assume my dash is the original.
03-24-2012, 08:05 AM | #2 |
Always on the hunt...
Re: A/C question
1972 was the first year for an in the dash factory type A/C setup on the suburbans and was refered to as Front & Rear A/C which also included the rear section only headliner mounted a/c pod. If talking just factory a/c and not dealer installed, the 71 and prior burbs only had a headliner-roof mounted a/c setup that ran from the front to the back and had no a/c controler or a/c vent option in the forward dash. Mel
03-24-2012, 01:17 PM | #3 |
Re: A/C question
The rear only work great too! The one I found is actually two twin units together.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
03-25-2012, 04:52 PM | #4 |
Re: A/C question
Thank you for the info. I only have the hoses in mine. Are any of the other parts available?
03-25-2012, 10:07 PM | #5 |
Re: A/C question
The rear A/C unit from a 73-91 burb, including the housing can be fitted into a 67-72 and look like it was made for it. Very minor bracket fabrication is required....
For dash air, I prefer an aftermarket heat/cool/defrost unit because they mount completely inside the firewall. I'm not certain that even 72 dash climate control used the a/c as an air dryer for the defrost, blending a/c into the hot defrost air being blown on the windshield. I'm not sure when this de-fogging feature was started, but all the aftermarket heat/ac/defrost units incorporate this feature. |
