Old 03-24-2012, 02:12 PM   #1
LF_MN_71GMC
LF_MN_71GMC's Avatar
Four Wheel Drive Won't Engage
Hey guys, I have a 71 GMC 4x4 half ton with a NP205. Here's the problem. I suspected the four wheel drive was not working so I put it on jack stands to test it. I can see both front drive shafts turning when in four wheel drive. However, neither wheel rotates.
I figured this was due to the locking hubs not making contact on the driveshaft splines so I took the hub off and manually slid the locking portion onto the splines and tried again. This was to ensure the shaft was locked onto the rotating assembly.
Result, now the drive shaft won't rotate when engaged. I remove the manual engagement locking portion and the drive shaft spins again. Thoughts?
Any help would be great.
1971 GMC 4x4 half ton np 205
1969 chevrolet camaro
1984 K10; 4" lift; sbc;
Build link
http://67-72chevytrucks.com/vboard/s...d.php?t=647172
LF_MN_71GMC is offline   Reply With Quote
