03-25-2012, 12:11 AM | #1 |
Very impressed with Monroe Sensa-trac shocks!
Wish I did this much sooner. Dropped my 87 4/6 about 2 years ago. I used the supplied Doetsch-Tech Nitro Slammer shocks that came with the kit. Front is dropped via 2'' Belltech coils and 2.5'' Spindles. Rear is a flip kit, western chassis shackles at 1'' hole, and c-notched.
I was sick of all the jarring, bouncing and harshness. First I tried lowering the pressure in the BFG Radial T/A's to 30 which helped. Then I tried rear shock extenders to get a better shock angle, which really didn't help at all. I read on here that one of the softest riding shocks you can buy are the sensa-tracs. I was a bit hesitant on if the oem length shocks would work but I figured what the heck. The fronts fit perfectly with the 2'' coils. In fact, the Sensa-Trac front shocks are an inch shorter than the Doetch-Techs.... go figure! The rears are certainly longer than the doetsch-tech. It is a must to run shock extenders on the rear using the oem length shock. I haul basically no loads in my truck so they should work fine for me. If you plan on using your truck to haul stuff, you may want to research a shorter length. The difference is night and day. Those Doetsch-Tech's are going straight to the garbage. I recommend these shocks if you are looking for a softer ride. Truck still corners excellent and it's not like too soft where it's bottoming out and blowing thru travel.... it's perfect
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch |
03-25-2012, 03:49 AM | #2 |
Re: Very impressed with Monroe Sensa-trac shocks!
I used front shocks for a 73-87 4x4 on the rear of my old 74 that had a flip kit (8-leaf spring pack), drop shackles, & shock extenders. It required a little tweaking but they worked well.
03-29-2012, 06:35 PM | #3 |
i run these on my 67, love em
1967custom |
04-28-2012, 02:56 PM | #4 |
I work at the plant where those shocks are made.
Glad to hear you are happy with your purchase. Steve
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e) 1990 K1500 Daily |
04-28-2012, 05:57 PM | #5 |
Can you set the record straight for me? It is my understanding that the sensitrac valving is very close to the 'inertia valve' type like the bilstein shocks. I have always thoght that the sensitrac was a great shock for the money, and on the dyno it reacts the same as other big $$ inertia valve shocks. I have never cut one up to see ?????
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
04-28-2012, 09:47 PM | #6 |
Yes. The sensi trac is geared to be a direct competitor to the other inertia type shocks on the market. It uses a small weight assembly to effect the valving based on the amount of "shock" delivered to the suspension.
04-28-2012, 11:25 PM | #7 |
How about some part numbers on these shocks? My 69 c10 has a 4/6 drop which shocks would I use. Also I'm thinking about raising the truck to 3/5 would I still be able to use the same 4/6 shocks for the 3/5. Oh yeah the truck is a l/b thanks.
Posted via Mobile Device |
04-28-2012, 11:27 PM | #8 |
I just make the parts, I don't know part numbers. But you should be able to use the same shock.
04-29-2012, 11:06 AM | #9 |
Maybe rob can chime in on this also rob do you sell the Monroe's
04-30-2012, 12:27 PM | #10 |
Part numbers would be good. I will be running stock suspension geometry, only plan to lower the front end 2-1/2 with drop spindles.
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
04-30-2012, 01:12 PM | #11 | |
Grand PooBaa Member
Just lowered my 69 yesterday from a 3/4 to a 3/5, now thinking about a 5/6 drop, my question why are you raising your truck up? Just curious. |
04-30-2012, 04:55 PM | #12 |
Just about done with my ls conversion going to let my daughter 16 drive a little after she learns to respect the truck. This truck is a clean dd and currently rolling on 17s thinking of going to truck rally's cause longer lasting tread wear and cost of 15s. Those doestech shocks really suck I got them when I purchased the shock relocator kit from cpp thought I really had something till I went out for test drive thought I was riding in a box of rocks. I originally had a set of Monroe's on the truck and rode great but didnt think they were the right shocks cause they were laying around and I just threw them on the truck what a mistake getting rid of them.
04-30-2012, 08:00 PM | #13 | |
'69 Chevy SWB
For everyone looking for part numbers,take some measurements and find the one you need here: Click Here
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
04-30-2012, 08:15 PM | #14 | |
05-01-2012, 08:08 PM | #15 | |
'69 Chevy SWB
glad I could help. I just know not every truck is the same. Yours may be lowered the same but could be a little off. It's always worth the little extra time to measure and order what you know will fit.
05-03-2012, 12:17 AM | #16 |
Can anyone elaborate on the correct way to measure for shocks just want to do it right before spending my truck is 4/6 hope I'm not asking a stupid question thanks.
05-03-2012, 10:00 AM | #17 |
I am certainly no expert, but the attachment from stealthy has details as to how to determine which Monroe units you need, if you have stock geometry, and if the shocks on the truck are correct to begin with. I would bet that robnolimit would be able to help out if your geometry has been altered.
05-03-2012, 06:30 PM | #18 |
I just bought a set for 100$ at advance auto parts. Love them.! They came out to $155 but I used the 50$ off 150 coupon code to get the price i paid for. Code is VISA. Really helped reduce body roll and the ride is much better now.
05-03-2012, 07:08 PM | #19 |
chevy runs deep
Part # please
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
05-03-2012, 08:31 PM | #20 |
I just looked them up on the website for a 68 C10
05-03-2012, 08:53 PM | #21 |
Vannatta20 is your truck dropped if so how much what part # mine is 4/6
05-03-2012, 09:02 PM | #22 |
Mine is all stock. front and rears
Part No 37040 part no 37049 http://shop.advanceautoparts.com/web...GRPSHOCAMS____ http://shop.advanceautoparts.com/web...GRPSHOCAMS____ Product Subtotal: $163.96 Discounts: -$50.00 Shipping Charges: $0.00 Tax: $0.00 Total: $113.96 |
05-03-2012, 09:40 PM | #23 | |
05-03-2012, 09:43 PM | #24 |
My truck is a 68. I would look up shock replacements for your year and model on the site.
05-04-2012, 03:37 PM | #25 |
C-10 Club Member
would love part #'s for a 98 tahoe 2dr dropped 4/6 with rear shock extenders.
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
