Old 03-25-2012, 01:03 PM   #1
1965zac
5 lug choices?
This is my first post on here. I just bought a 1965 SWB custom trim truck and want to go 5 lug on it because there are more choices in wheels and 6 lug wheels look weird to me. I'm 18 so I'm on a budget. I was told by a guy at the junkyard to put a 73 c10 rear end in and it would work great with a little fabricating.
What have you guys put on your trucks or what is the best way to go that won't cost too much?
1965zac is offline   Reply With Quote
Old 03-25-2012, 01:51 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 5 lug choices?
Welcome
Yes, swapping the front and rear off a 73-87 c10 will be the most economic route.
Lots of threads here on that.
Start in the FAQ's for the 60-66 trucks.
The biggest job will be welding trailing arm perches to the 73-87 axle.
Most here recommend finding a 73-87 donor, and get all the goodies. Power Steering, Power Disc Brakes, and more.
66 C20 Service Truck:
Old 03-25-2012, 10:38 PM   #3
Captainfab
60-66 Nut
Re: 5 lug choices?
Welcome to the forum
I agree, there is a ton of info to be found in the 60-66 FAQ section. It can be found at the top of the page.
Old 03-26-2012, 09:34 AM   #4
1965zac
Re: 5 lug choices?
Thanks guys!
will the width different in the rear ends cause a lot of trouble?
Old 03-27-2012, 12:20 AM   #5
Captainfab
60-66 Nut
Re: 5 lug choices?
That partly depends on how wide of wheels you plan on running. The increased width can be compensated for with the correct wheel backspacing.
Originally Posted by 1965zac View Post
Thanks guys!
