Old 03-25-2012, 11:58 PM   #1
Dieselholic92
Dieselholic92's Avatar
Where can I get them?
Where can I get front and rear shock bolts for my 81 Chevy? I'm talking about the ones on the frame. I bought new Monroe shocks but they didn't come with them and the ones on my Chevy were so gone I had to torch them off. Can I just get them at Napa or O'Reillys?
Semi professional heavy equipment operator
Amateur mechanic
Dieselholic92 is offline   Reply With Quote
Old 03-26-2012, 12:04 AM   #2
sethv
sethv's Avatar
Re: Where can I get them?
Could get grade 8's at the hardware store.
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
Old 03-26-2012, 01:25 AM   #3
jhngardner367
jhngardner367's Avatar
You should be able to get them at NAPA,or CarQuest. I've bought them separately,before.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 03-26-2012, 03:00 AM   #4
the_ocho
i got 3.5 in long 5/8ths bolts from lowes with two nuts and washers for each bolt. one of those set ups on each corner of my truck. the shank of the bolt is the perfect lengh for me to sandwich the shock with a washer on each side and tighten down the first nut on the threads and leave enough play on the shock. simply side that through the hole in the frame and tighten down the second nut with the factory lock washer installed and wam bam your done.
the_ocho is offline   Reply With Quote
Old 03-26-2012, 08:23 AM   #5
Weasel Diesel
Thats odd... I used to sell Monroe's and they used to come with the shock... Maybe they are cutting back to save $$$.
Weasel Diesel is offline   Reply With Quote
Old 03-26-2012, 08:41 AM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Any good parts store should have them
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-26-2012, 09:53 AM   #7
J Knight
J Knight's Avatar
I replaced my front shocks about six months ago and they came with all the frame mounting hardware but not the bottom bolt/nut for the control arm.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 03-26-2012, 11:11 AM   #8
Dieselholic92
This weekend I'll have to check the parts stores. I thought it was odd that they didn't come with anything else but oh well.
Amateur mechanic
Old 03-26-2012, 11:57 AM   #9
crazeetxn
crazeetxn's Avatar
I'd check a website that sells them and see what bolts they're supposed to have then go do what sethv said.
1st - '68 long bed
2nd - '81 SWB
Now - '86 SWB, Edelbrock 1406/stock 350/700r4
crazeetxn is offline   Reply With Quote
Old 03-26-2012, 03:37 PM   #10
76stepsidechevy
autozone has them in the "help" section. I dont think there more than a couple bucks a piece. I think the come with bushings too.
76stepsidechevy is offline   Reply With Quote
Old 03-26-2012, 07:37 PM   #11
Axle
Axle's Avatar
Frame bolts should be packed with all the Monroe shocks. For the fronts; p19 parts pack which has the frame "bolt". (the lower is a standard bolt so you don't get that one).
You can double check whatever shock it is you got at;
http://www.monroe.com/catalog/e-Catalog
Go back where you bought it and see what they come up with. Worst case, return them. And buy them somewhere else and start doing what I do (after the same inconvienince you are going through), open them up in the store to make sure everything is in the box (and correct part pack) before paying for them.
Alex.
Axle is offline   Reply With Quote
