05-05-2003, 10:45 PM | #1 |
Got a 72 GMC and need to know what back spacing I need to put 10'in welds on the ass
Hey guys, I need to know what back spacing I need on my truck
ofr 10'in welds on the back and the 3-4'in on the front runners. I have a 4-6 drop.Also what size slicks do I need for the rims? Thanx SS72GMC
1972 GMC SC/LB 350/TH350 4/6 Drop http://www.dfwstangs.net/hosting/SS7...ustins_sig.jpg |
05-05-2003, 11:21 PM | #2 |
Assuming you don't have tubs, 4" to 4-1/2" backspacing is standard. Good luck, Scott
Silence is golden, duct tape is silver. - Scott |
05-05-2003, 11:24 PM | #3 |
Thanx man but what size tire shouldI run?
SS72GMC
05-06-2003, 12:54 AM | #4 |
I run a 265/60 15 in the front on a 7 1/2 rims
and 295/50 15 in the rear. on a 8 1/2" rims I am close to rubbing on the rear. but i am about 2" above the tire on the lowering, with out a load in bed
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ "Why couldn't you have just put the bunny back in the box?" ~ |
05-08-2003, 01:54 PM | #5 |
tire and rim size
When i did it for my dropped 56 f#$d i just measured the space with a tape measure and then subtracted an 1" to figure the tire size and for the rim backspacing i measured from where the backplate and wheel studs meet. They didn't make the steel wheels with the required back spacing so i got the max they would do and got a 1/2" wheel spacer and they fit perfect and looked badass.
Good luck |
05-08-2003, 08:39 PM | #6 |
Thanx man !!!
SS72GMC
05-09-2003, 04:45 PM | #7 |
on a 10" wide rim u can put a 295/50/? on it
Most likely your loacal tire dealer should know or contact weld via there web site
05-09-2003, 09:42 PM | #8 |
Formerly yellow72custom
295/50-15 tires fit a 15x10 rim great. The rim and the tire look really well matched, and pretty bad a$$ too. However, 50-series tires ride like crap, and everyone i know that has them have problems with them wearing out. I am hoping to go with a 15x10 wheel and a 275/60-15 tire on them, i think it should look pretty good with the 15x8 rim and 255/60-15 tires i have on the front now.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
05-10-2003, 03:06 PM | #9 |
275 are a tight stretch on a 10" rim, might roll off rim on a dounut spin!!! I used Remington tires 295/50/15 on mine, ride seems fine, I also have them on my 81, and it holds up great. I tried GF G's and Good years. They did not hold up that well, and where more expencive (remingtons where about $100. each and the others about hmmm $130 each)
