Old 03-26-2012, 11:12 AM   #1
dieselmec1993
350 tbi years
hey guys i bought a 1990 1500 burb that had a tbi 350 in it and a 700r4 trans im wondering sence po took out the engine and trans before i bought it what year motor can i got get and hook up to harness wanting a tbi motor are the 88-91 the only motors that will work
1977 k20 frame with 85 cab and hopefully 6.5 diesel.
1981 c20 long box 250 3 on the tree daily driver.
1982 k25 with 86 cab tired 350 4speed trans 37in military tires.(project Frankenstein). 8.
1984 c30 crew cab dually 6.2diesel next project
only 18 and finshed 5 projects started when i was
dieselmec1993 is offline   Reply With Quote
Old 03-26-2012, 11:34 AM   #2
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: 350 tbi years
I'm pretty sure 87-94 tbi motors are all the same, but just make sure you get the cpu if you get the engine and trans from a truck with the 4l60e or 4l80e trans, they are electronically controlled unlike the 700r4.
2020 Silverado Trail Boss - 6.2/10spd
Dalaigh is offline   Reply With Quote
Old 03-26-2012, 12:48 PM   #3
Jonboy
Slots go on anything!
Re: 350 tbi years
You might have a couple of minor differences, like the TPS is a different design in the later years, and they switched to serpentine belt drive and accessories around '90 or so.
1974 Jimmy- 5.3/4L80e/NP241
Old 03-26-2012, 11:27 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: 350 tbi years
I am pretty sure '87 TBIs had the old dual belt setup and a couple other differences. Same as '95 I think they had a few more upgrades then the other years. That being said the '87-'95 350 TBIs should all work for you. If you do get a whole donor truck do make sure to pull the computer and everything to go with it. Good luck.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 03-27-2012, 09:54 AM   #5
dieselmec1993
Re: 350 tbi years
do i need a computer if my truck has the full harness
Old 03-27-2012, 10:31 AM   #6
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: 350 tbi years
It's best to get it anyway just incase. Like stated above there are small differences in the engines over the years.
