03-26-2012, 12:03 PM | #1 |
neutral safety switch
Anyone know how to hook up a neutral safety switch? (The one on the column)
I got my backup lights working off it. I have two more lugs left on switch. I'm assuming I can run a wire off each lug and splice it into the wire going to solenoid. Does that sound right and if so what color is the solenoid wire on ignition switch?
Friends don't let friends drive Fords |
03-26-2012, 08:42 PM | #2 | |
Re: neutral safety switch
03-26-2012, 10:27 PM | #3 |
Resistance is Futile
I've only done it on aftermarket shifters, but it sounds correct what you are describing.....solenoid wire should be purple in stock set-ups.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-27-2012, 08:06 AM | #4 |
Thanks Man, I need to get this done. I was working on backup lights and had trans in reverse, some friends came up and I started it for them and about ran over my S-10.
03-27-2012, 10:22 AM | #5 |
Yes,
On a 64 one wire goes from the far left terminal on the ignition switch (laying on the floor of the truck - looking up at the switch) to the neutral safety switch then another wire from the neutral safety switch to the starter solenoid. The factory used 12 gauge wire for this. |
03-27-2012, 06:44 PM | #6 | |
04-04-2012, 04:45 PM | #7 |
Since I wired the switch up, sometimes when you crank truck and pull truck in drive the starter gets activated for a split second. Has anyone ever experienced this happening to them? If so what is causing it?
04-07-2012, 09:00 PM | #8 |
Found the problem, just needed to tweak the adjustment a little.
