Old 03-26-2012, 02:35 PM   #1
gettmoneyy7
gettmoneyy7's Avatar
Test start on a 305
Trying to test start my 86 305 c10, restoring my truck, i have the frame and and four tires and the motor and trany in the frame, and i wanted to crank the motor before i bolt the cab on, i put a hose on the trany lines so they don't spray all over, The drive shaft is slid in the tranny, i put the crank on TDC/ piston at the top of cylinder on #1, hooked gas lines up to a spare tank iam getting fuel, i hooked a wire to the distributor 12v red wire, to my battery, wired the starter, is this how i would crank the motor ??
gettmoneyy7 is offline   Reply With Quote
Old 03-27-2012, 11:09 AM   #2
gettmoneyy7
Re: Test start on a 305
I wired it up and hit the starter, and it fired right up
Old 03-27-2012, 05:55 PM   #3
Goldfinger
Goldfinger's Avatar
very nice
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
