Old 03-26-2012, 02:46 PM   #1
Marlar
'69+ GMC Doghouse
Hood - minor pinhole rust on leading edge as well as a light, quarter-sized dent that could be pulled or Bondo'd over. Otherwise straight.
Core Support/Wheel Wells - typical cancer in wheel wells. Core support also has rot, but I've seen worse. It could be saved with a little bit of welding and sheetmetal. Or it has good headlight buckets you could transfer to a Chevy version.
Driver Fender - cup is dented with minor cancer. Not a hard fix, but would involve welding. Woodgrain trim is bent a little at a corner, but can be pushed back down and is perfect for a driver.
Passenger Fender - good shape. Appears to be some surface rust on cup, but I didn't see any cancer.
Sorry, the grille's already been sold, but I do have the correct GMC hood latch. Bumper is available separately.
$450
Marlar is offline   Reply With Quote
Old 03-27-2012, 10:12 AM   #2
Marlar
Re: '69+ GMC Doghouse
Bump.
Old 03-28-2012, 05:57 AM   #3
gmc 2500 4x4
$450
cab any good?
gmc 2500 4x4 is offline   Reply With Quote
Old 03-28-2012, 08:17 AM   #4
Marlar
Typical problem areas at the bottom. It's got carpet on the floor so I didn't even bother looking closely. I can check if you like. This one isn't an A/C cab, but I might have 1 or 2 in the same shape if you're interested.
Old 03-28-2012, 05:43 PM   #5
gmc 2500 4x4
snap some pics please, i'm interested
Old 03-29-2012, 03:04 PM   #6
Marlar
I was thinking it at least had a decent ceiling, but that's rusting, too. Rockers, corners, and the back of the floor where the jack goes are all cancerous. It does have an aqua headliner and visors, though. The visors are in decent shape, but I'm not sure about the headliner.
Old 04-02-2012, 08:11 AM   #7
Marlar
Bump.
