airbag help
ok so wirh the rear bag install im seeing 3 holes in the bag and i know it only takes one bolt do i need to block the other holes or do they not go through sorry for all these dumb questions never seen a bag befor today....and thanx again
Re: airbag help
Not sure what bags you have. My SS bags have 3 holes. The two outter holes are for mounting the bag. The inner hole that goes through the bag plate into the bag itself is for the air supply. the bottom of the bag has just the 2 mounting holes.
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
Re: airbag help
The extra holes are for mounting, and the "inlet" hole will be large and will go through. What kind of bags do you have?
Re: airbag help
like others have said....there will be a place to put your airline. some bags have 1 airline hole, some have 2. you only need 1 airline hole the other can be blocked off with a threaded "plug". you need 2 bolts to thread in the top to mount and you need 1 bolt on the bottom to mount. if you have 3 bolt holes on the bottom, you can use 1, 2 or all three for mounting the bottom of the bag
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
