Old 03-26-2012, 08:00 PM   #1
dragonlord2167
Problem starting 71
Hi there new here and have learned a lot from reading thru the post and thank you for it but I'm truly dumb founded I have a 71 chevy with a 350 four bolt main its a brand new crate engine and i just installed it I put everything on her brand new except the distribuator its HEI but it has a new 650 edelbrock carb new alum intake new fuel pump like i said everything is new what my problem is in the morning or after it sits a while it fires up great but after driving around and when I shut it off and go to start it all it does is turn over unless I put it to the floor and she will start checked all vacuum hoses can't find a leak but when its running it seems to be running ok except when I stop at a light it wants to die down sometimes I tried to turn in and adjust mixture screws and they don't do anything for her it doesn't change anything so I'm hoping someone here might be able to give me some pointers and maybe help out.
dragonlord2167 is offline   Reply With Quote
Old 03-27-2012, 09:11 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Problem starting 71
ttt
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-27-2012, 09:17 AM   #3
eldogg
eldogg's Avatar
Is the choke on the carb hooked up?
eldogg is offline   Reply With Quote
Old 03-27-2012, 09:17 AM   #4
70cst
70cst's Avatar
Howdy dragonlord2167 ...
to the form and from Ohio. Here is a bump for you. I am sure you will get some replies soon.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-27-2012, 10:21 AM   #5
dragonlord2167
Yes choke is hooked up it works fine first things in the morning choke is kicking in its after it runs for a little bit and shut down and go to start it back up
Old 03-27-2012, 11:22 AM   #6
Shyguy
Junior Member
Shyguy's Avatar
Edelbrock carbs have a problem with heat soak when the engine is shut down boiling the gasoline out of the carb, also they tend to be fuel pressure sensitive.
Usually to solve the heat soak problem a phenolic spacer is installed under the carb and to solve the pressure sensitivity a pressure regulator is installed.
First I would go with the phenolic spacer and see if that helps.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 03-27-2012, 11:27 AM   #7
socalkevin68
socalkevin68's Avatar
my edelbrock gave me same problem you are describing..i put on fuel pressure regulator on and havent had a probllem..think 4psi is the setting...
socalkevin68 is offline   Reply With Quote
Old 03-27-2012, 11:54 AM   #8
midniteblues
midniteblues's Avatar
I havent had any problems with heat soak with a eddie on a aluminum intake but i did with a cast iron one an the spacer helped but thats just me cant realy say for anybody else. my eddie likes a pedal pump or two too start when its really hot.bogging down at lights though sounds like you might have a mis tuned choke and fast idle screw. not the bigger idle screw but the smaller one under the fast idle cam.a plug reading could confirm this.eddie carbs sure dont like too much pump pressure either.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 03-27-2012, 01:20 PM   #9
dragonlord2167
Ok thanks I'll try those whats stumping me is its doing the same thing as the old carb which was a quad and allum intake I replaced everything new when I put new engine in except for the distr and coil thats why I was wondering if the distr might be bad
Old 03-28-2012, 04:10 PM   #10
68 TT
Still plays with trucks
68 TT's Avatar
You may have a vapor lock problem upstream from the engine. Your exhaust may be too close to a fuel line before the fuel pump. Check as it exits the cab and heads forward for any areas where the fuel line crosses over or follows along with the exhaust routing.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 03-30-2012, 11:21 AM   #11
dragonlord2167
Ok this is what I've done I put the spacer I put a new ignition modulator in the distibulator and ran the fuel line straight up where its in between the carb and valve covers and put a new filter but what I see is going on is my fuel is bleeding out of the filter and goes back down thru fuel pump I put a new fuel pump last week when I put the new engine in i sat and watched it the truck will turn over till the gas gets back in the filter and its starts right up so now I need to figure out why its bleeding down.
Old 03-31-2012, 08:02 AM   #12
Shaun1162
Shaun1162's Avatar
How hot is your engine running? I had almost the same exact problem with my truck.... Edelbrock card + intake, new crate motor, etc... Turned out the thermostat that came with the motor was way too hot.
- 2010 Silverado
- 1984 Chevy M1028 (K-30)
- 1969 Chevy C-30
- 1933 Ford Stock Car
Shaun1162 is offline   Reply With Quote
Old 03-31-2012, 12:08 PM   #13
dragonlord2167
Oh heck I'm thinking I put 190 something in it mine didn't come with one and I put it in thinking its 192 194 something like that.
Old 03-31-2012, 03:03 PM   #14
Shyguy
Junior Member
Shyguy's Avatar
I normally run a 180 degree thermostat in my trucks, including the '92 with a 454.
Old 04-01-2012, 07:17 PM   #15
Shaun1162
Shaun1162's Avatar
I had a 195 in mine, and went to a 180. Seemed to help cooling quite a bit, and it's not boiling the gas in my carb anymore...
- 2010 Silverado
- 1969 Chevy C-30
Old 04-02-2012, 08:37 AM   #16
dragonlord2167
Ok thanks guys I'll try that and see if it helps I sure hope so sure hate after spending all this money and having this issue I sure appreciate all the advise.
