Old 03-26-2012, 09:43 PM   #1
Nobby
Nobby's Avatar
CPP conversion axles question
OK I got my axles in from CPP, so I'm pumped to get them in and set this thing on the ground. The holes are not big enough for the 1/2'' studs....It's to late to call CPP and I don't want to be mad all night. Has this happen to anyone? Do I need to drill them out? Maybe get some 7/16'' studs?
Thanks,
Nobby is offline   Reply With Quote
Old 03-26-2012, 11:38 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: CPP conversion axles question
5 lug axles use 1/2" studs. I think the holes in the wheels are designed for 1/2" studs and I don't think you'll get wheels to tighten up correctly with the smaller ones.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-26-2012, 11:48 PM   #3
Captainfab
60-66 Nut
If they're 6 lug axles, then they will be setup for 7/16" studs. If they are 5 lug, they should be setup for 1/2" studs. Either way, I would drill them out for 1/2" studs. Probably overkill on 6 lug, but that's what I would do.
Old 03-28-2012, 12:56 AM   #4
Rooster's 67
Rooster's 67's Avatar
when you say they dont fit do you mean that the threaded part wont fit or the part with the Knurl ? the threads should go all the way through until the knurl is against hole, then use a lug nut to pull the stud home. you may need washers to have space for the knurl to come thru the face of the flange and seat completely on the back of the flange.
Heres the first video i found about how to replace/install studs
http://www.youtube.com/watch?feature...&v=XX9te2iFH3E
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 03-28-2012, 08:17 AM   #5
Nobby
Nobby's Avatar
Thanks guys,It is the 5 lugs axles.The holes for the studs were to small and the threaded part of the studs would'nt fit. Talked to the guy at CPP and he said "sometimes you have to ream out the holes". I'm well aware of fabricating on older cars but when you spend good money on a new part it should work. Anyway I brought them to my friends machine shop and he drilled them out for me. Everythings fine now.
Thanks,
Old 03-28-2012, 08:52 AM   #6
scottofksu
scottofksu's Avatar
Thanks,
Thank you Taiwan? I agree with your sentiment; it is ridiculous that you had to drill out brand new axles. However, I wonder if it was a problem with the manufacturer of the axles or the studs... Given that (I assume) none of the studs fit, I would guess it was a problem with the axle manufacturer...
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
