Old 03-26-2012, 10:12 PM   #1
1959Chev
1959Chev's Avatar
Calling all 9" rear guys
Has anyone adapted ls1 brakes to a 9" rear? I picked up a 9" for my 59 and have a set of ls1 brakes on the shelf I would like to use. I will also be installing ls1 brakes on my front subframe. I know some people out there has installed ls1 rear brakes on a 9".
Thanks,
Eric B.
2006 Chevy Silverado 3500(Duaramax/Allison) - DD
1997 Honda Civic - Work Beater
1981 Chevy Malibu - Race Car
1959 Chevy Truck - Project
http://67-72chevytrucks.com/vboard/s...d.php?t=481442
2006 Honda Accord - Wife's ride
1959Chev is offline   Reply With Quote
Old 03-27-2012, 09:06 AM   #2
1959Chev
1959Chev's Avatar
Re: Calling all 9" rear guys
Come on guys I know some of you have done our a2 least seen it done. Or is my only option housing ends for ls1 brakes from moser. If I go this route please tell me I can keo my strange axles...
Old 03-28-2012, 11:14 AM   #3
1959Chev
1959Chev's Avatar
Found out ls1 brakes won't work unless i get new axles... Looks like I will be going with an aftermarket disk brake kit. Found one that would let me use the 5x4.75 lugs. axles already drilled for that and 5x4.5. I'll just need to move my studs to the 5x4.75 holes.
Old 03-29-2012, 09:28 AM   #4
Kateaux
Kateaux's Avatar
I found an excellent rear brake kit on fleabay. I have a 9" Torino style. The whole kit includes, 79-81 Firebird Rotors Slotted and Drilled, GM Metric Caddy Emergency brake calipers, all brackets, all cables, hoses, bolts, etc. for $299.99 plus $50 shipping (very heavy). The have kits for small and large old style too. All the rotors and calipers are zinc coated as well.
Kateaux
55 Camelow
1958 3100 w/55 frontend and 55 Cameo Bed (in progress)
Kateaux is offline   Reply With Quote
Old 03-29-2012, 12:31 PM   #5
jimig1
jimig1's Avatar
Kateaux
55 Camelow
This is what I'm using. I already had the Rotors, GM Metric Caddy Emergency brake calipers all I had to buy is the caliper brackets and have the bolt pattern redriled in the axles since they were 5 on 5.5.
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 04-02-2012, 04:15 PM   #6
1959Chev
1959Chev's Avatar
which rotors are you guys using? I didn't think camaros come with disk on back until third gen..
Old 04-02-2012, 04:36 PM   #7
jimig1
jimig1's Avatar
I'm using 1978 Cadillac Seville Rear rotors
MSRA Member
-George Carlin
Old 04-02-2012, 09:27 PM   #8
xpickup
xpickup's Avatar
1959Chev, I bought the kit from Speedway motors for my panel. I am cheap so I bought the weld on bracket kit instead of using the bolt on kit. It uses 2 piece rotors with GM metric calipers with the emergency brake. I bought the brackets that has the gussets built in.
Shannon
xpickup is offline   Reply With Quote
