Old 03-27-2012, 01:03 AM   #1
Square_78
Square_78's Avatar
I hate rust...
What a waste of a day...
Finally got my flip kit in from Summit Racing... went and bought a nice floor jack and attempted to install my front drop springs on my 78 C10... Im fairly mechanically inclined so I figured it would be easy... spent about 2 hours trying to remove the RUSTED cotter pin from the lower ball joint castle nut. Then spent an hour trying to loosen the same castle nut.. WTF! I even had a 3 foot breaker bar and an 8 lb sledge and the thing wouldnt budge. I sprayed it with penetrating oil a couple days ago so I thought everything would come off easy. Yeah right! I dont have access to a torch, and already had my wheels off my truck so I couldnt go to the store and buy one... What a waste of a day. Had to put everything back together and I'm still rolling at stock height
Now Im having second thoughts about installing my flip kit at my house. If the back is anything like the front, Im gunna be screwed. I guess Im going to have to take it to a shop and get them to put the springs and flip kit in. I really wanted to do it myself. Stupid rust!
Square_78 is offline   Reply With Quote
Old 03-27-2012, 01:16 AM   #2
Low84
Low84's Avatar
Re: I hate rust...
I feel for ya!
This kinda thing happens to me more often than I'd like. Still got a real nice inner bruise on my hand and my mishap happened two weekends ago
Low84 is offline   Reply With Quote
Old 03-27-2012, 01:45 AM   #3
Square_78
Square_78's Avatar
Re: I hate rust...
If i had air tools and a oxy/acet torch. things might be different... But then again, if i had all that, then I would buy a welder and air bag the thing. Me and my little garage full of hand tools is apparently no match for Canadian rust!
lol
Old 03-27-2012, 07:08 AM   #4
xrcr
Re: I hate rust...
If it's not rust it's something else. I've been building the doors on my 76 for a week and they are still winning. Paitence is a requirement...
xrcr is offline   Reply With Quote
Old 03-27-2012, 07:09 AM   #5
xrcr
Re: I hate rust...
If it's not rust it's something else. I've been building the doors on my 76 for a week and they are still winning. Patience is a requirement...
Old 03-27-2012, 07:31 AM   #6
BigBlocksRule
Re: I hate rust...
You only need two tools:
1) 1/2" drive impact wrench
2) Blue tipped crescent wrench (a.k.a. torch)
If you aren't already using it, use PB Blaster to cut through the rust, WD-40 isn't worth squat in this application.
BigBlocksRule is offline   Reply With Quote
Old 03-27-2012, 07:34 AM   #7
donut
donut's Avatar
Re: I hate rust...
You do what you gotta do.
Yes, rust sucks, but working on an old truck (or newer one) sometimes you have to deal with it. Go in with the mindset, if it's threaded, it's trash.
Wire brush and penetrating oil is a good start. Feel free to soak them days in advance.
Heat can help, even a little propane torch (plumber's, not "crack pipe") is sometimes enough. Impact to break them loose. Hammer, not air tools, just enough to "shock" the fitting. I had an old set of wrenches from a yard sale, perfect to beat on. Lot's of times more effective than brute force.
Something to cut metal. (For the stubborn ones, old ones still have to come out) Sawzall, grinder...
Shop can save you a lot of grief, but you will pay. There is a shop close to me that does charge more if they have to deal with old rust.
My former truck had a dealer installed snowplow, I have seen rust.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 03-27-2012, 08:49 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
Re: I hate rust...
sometimes the wire brush
sometimes a quick sand blast
for sure soaking helps
my impact won't crack rusty nuts,seems more threads rip out with no control
manual for me,you feel it loosen up better
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-27-2012, 10:46 AM   #9
esbstuff
Re: I hate rust...
esbstuff is offline   Reply With Quote
Old 03-27-2012, 10:49 AM   #10
nekkidhillbilly
Re: I hate rust...
pb blaster is your friend
nekkidhillbilly is offline   Reply With Quote
Old 03-27-2012, 11:44 AM   #11
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: I hate rust...
The back is probably not going to be any easier. As stated, lots of patience is required. I use anti-seize on almost everything I re-assemble these days, just in case I keep it long enough to have to go through it again.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 03-27-2012, 11:56 AM   #12
chevymotocross
chevymotocross's Avatar
Re: I hate rust...
what he said
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 03-27-2012, 12:32 PM   #13
nekkidhillbilly
Re: I hate rust...
yeah wd 40 dont cut it
Old 03-27-2012, 04:10 PM   #14
DetroitIron
DetroitIron's Avatar
Re: I hate rust...
x2 on the use of anti-seize!
_______________________________________________
1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger"
1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel
DetroitIron is offline   Reply With Quote
