Old 03-27-2012, 02:51 AM   #1
GMC70c20
ls oil pans
I am going to be puting my lq9 together in a month or so and I was needing a different oil pan. It has the stock lq4 pan on it now and with the front end thats under it the engine would bolt up to the motor mounts but would be sitting on the pan. I was originally just going to rasie the motor up about 3/4 of a inch but it would sit at a 8 deg angle and I was wanting more like 3-5 (the motor mounts are not stock either). I found a pan made by kevko for a f-body are which was the kind pan I was planning on using. Has anyone used these before? did they seal well?
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
GMC70c20 is offline   Reply With Quote
Old 03-27-2012, 08:47 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: ls oil pans
Dunno about sealing, but if the dimensions are the same as the F-body, it should save you some space. Like most sheetmatal pans, it will require an external filter. Why not try a stock F-body pan?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-27-2012, 09:46 AM   #3
GMC70c20
Re: ls oil pans
I want to relocated the filter to make room for headers (2" primarys), and by the way I saw the build page for your truck its pretty efin sweet.
spray and pray baby
Old 03-27-2012, 09:37 PM   #4
jtp67-72
jtp67-72's Avatar
Re: ls oil pans
Here's best link to all the gm pans............jim
http://ls1tech.com/forums/conversion...-oil-pans.html
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
