Old 03-27-2012, 09:08 AM   #1
62 short step
62 short step's Avatar
Drivers door mirror location.
Did a search and couldnt find what i need. Does anyone have a pic with measurements for a 64 drivers mirror? The stock small, 3 hole mirror. PO filled in the holes on mine, need to drill out the filler and retap.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 03-27-2012, 09:39 AM   #2
1963c-10
1963c-10's Avatar
Re: Drivers door mirror location.
If you pull of the inside door cover, you can feel the nuts from the inside of the door. If you have a drill with an angeled head, you should be able to drill them out and then retap. Im sure that someone can get you external measurements from someone here too though.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-27-2012, 09:41 AM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
https://lh5.googleusercontent.com/-b...800/image1.jpg
Old 03-27-2012, 09:42 AM   #4
aerotruk63
aerotruk63's Avatar
Old 03-27-2012, 10:53 AM   #5
newbe351
I've heard that there are nuts on the inside of the passenger door as well. Does anyone know if a passenger side mirror can be installed in the same manner as described in post #2 above?
newbe351 is offline   Reply With Quote
Old 03-27-2012, 10:56 AM   #6
MisterC
MisterC's Avatar
Yes, the right side mirror can. The nuts are hit or miss, but I believe most trucks had the plate with the correct holes on the inside of the door. Mine did. I just had to use my own lock nuts.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 03-27-2012, 11:11 AM   #7
1963c-10
1963c-10's Avatar
yeah, mine had the support plate inside the passenger door, but had to get 3 nuts.
Old 03-27-2012, 11:18 AM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
FYI the dimensions provided above are for a 60-63. 64-66 mirror arms angle uphill toward the front. Post #14 on the attached thread may prove helpful:
http://67-72chevytrucks.com/vboard/s...t=mirror+mount
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-27-2012, 01:16 PM   #9
62 short step
Thanks guys! Last question, any idea on screw size? I had some but cant find them now!
1965 c-10
86 chevy c/k 20
Old 03-27-2012, 07:26 PM   #10
markeb01
Senior Enthusiast
markeb01's Avatar
They are 5/16x18. Early 1960 screws look like these with large serrated heads:
Later screws have smaller heads like these reproductions:
Originals look very similar but have a sharper edge around the rim of the head.
Old 03-27-2012, 09:17 PM   #11
62 short step
Thank you sir!
1965 c-10
86 chevy c/k 20
