Old 03-27-2012, 10:23 AM   #1
CrazyJesster
CrazyJesster's Avatar
Question drive by wire tcm
Im still kinda new to the ls stuff.
And I've found a 5.3 with ecm and.
Throttle control module.
Is this the drive by wire and will it require a pedal?
Project 82 ReBoRn http://67-72chevytrucks.com/vboard/s...d.php?t=441842
CrazyJesster is offline   Reply With Quote
Old 03-27-2012, 11:29 AM   #2
Daaaanz67
Re: drive by wire tcm
Yes yes
Daaaanz67 is offline   Reply With Quote
Old 03-27-2012, 11:34 AM   #3
CrazyJesster
Ok Ty is this an ok method to swap to?
Can it be switched to a cable?
Old 03-27-2012, 02:06 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
you can change to a cable pedal setup if you want, but the dbw isn't hard to mount or work with, assuming you have a matching set. Just make sure the tcm and ecm match, as well as the TB. If those are all kosher, you just need to find the matching pedal. Depends largely on year.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
