2wd vs 4x4 frame
Is there any difference between a 2 wheel drive frame and a 4 wheel drive frame. Will 4x4 parts bolt up to a 2 wd frame. Any help will be appreciated.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
#2 | |
Still plays with trucks
Re: 2wd vs 4x4 frame
I know the 67-72 4x4 parts will fit the front end of both styles. I bought a 69 C20 that had trailing arm rear but the front had been converted to 4x4 with correct parts. The rear section if I remember right is formed slightly different between the two styles of frames. If you have a leaf spring frame then it won't need to be changed at all to do the 4x4 conversion. From what I have read it is far easier to just get a leaf spring frame to start from if doing the conversion. Most all Chevy trucks are trailing arm and most all GMC trucks are leaf spring from what I understand.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
The front suspension is not a direct bolt on. The rear shackle bracket needs to go through the parking brake cable indention, you must cut it out and weld in a flat piece to get the shackle in the right spot.
#4 | |
I didn't notice the missing parking brake mount area as the truck was just an incomplete shell / roller.
The rear of the frame on a 4x4 is more straight than either 2wd frame, both leaf and coil spring 2wd rear frame section kick in over the axle.4x4 goes straight to back of cab at 34 inches wide I believe. Gene is right about the front rear shackle mount.
Rob 72 C/10 (under reconstruction)(destruction ? LOL) 48 Willys CJ2A 1952 Super "A" Farmall (Grandfather's) |
You should be able to bolt 2wd leaf spring brackets to convert the rear, they are angled to allow for the step out.
Posted via Mobile Device |
Sounds like it isn't impossible. Like anything else, it will take some work. Thanks for all the input! I now have area's to look at for the swap.
