Old 03-27-2012, 07:53 PM   #1
purebred
Spare Tire Mounts?
What do all of you out there use for a spare tire mount? I have mine just thrown in the back, but would like to clean up the mount situation, any pictures of clean mounts? Thanks
purebred is offline   Reply With Quote
Old 03-27-2012, 08:30 PM   #2
k1rodeoboater
Re: Spare Tire Mounts?
Under the bed in the stock location is pretty clean if you aren't running a tank back there
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
Old 03-27-2012, 09:01 PM   #3
100%Chevy
Here's a thread with the fender mounts and my in bed mount.
http://67-72chevytrucks.com/vboard/s...d.php?t=505728
Mike.
100%Chevy is offline   Reply With Quote
Old 03-27-2012, 10:08 PM   #4
cb1965
cb1965's Avatar
quick question.. how do you mount the tire under the bed. i have the long bracket but how does it hold the tire????? any piccs?
thanks
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 03-27-2012, 10:37 PM   #5
late68
late68's Avatar
I have a tire mount for sale....!!!! lol ( underbed mount )
1968 C10 SWB Dropped 5 in tha back 3 in tha front
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902
late68 is offline   Reply With Quote
Old 03-28-2012, 07:28 AM   #6
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Old 03-28-2012, 08:34 AM   #7
purebred
Thanks but I have the fuel tank in back, and I don't have cutout for side mount, thought maybe some of you might have fabricated some kind of mount for inside the bed.
Old 03-28-2012, 08:42 AM   #8
1963c-10
1963c-10's Avatar
You might be able to modify a fleetside in bed spare tire mount. I have a pic of one...I haven't heard of a fleetside using this style of mount in the bed, but like most things, if you have the time and money...it could be made to work.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-28-2012, 11:26 AM   #9
Surfdaddy
Surfdaddy's Avatar
I have the stock under bed mount and though it’s pretty clean it is a total pain to get the tire up there. The only way is with a floor jack and that was still a pain. It could be harder because the tire I’m using is the same as what’s on the rest of the truck and is wider than the 7” stock tire. There is one plus besides getting the tire out of sight, it adds weight behind the axel so the ride is a little better than when the bed is empty. I’m running 235/75- 15 (stock rims) but if you go to a skinny tire it should be much easier
1961 GMC. Start date 1/20/2011
Past projects:
1958 Fleetliner 14ft Runabout
1966 Caprice 2dr
1970 VW Squareback
Surfdaddy is offline   Reply With Quote
Old 03-28-2012, 08:11 PM   #10
old cruiser
old cruiser's Avatar
Why don't you chase up a spare tyre winch as found under some small jap trucks and over here in all holden utes from 1971 to today. They just use a crank handle to wind up or down no other lock device needed when wound up.
old cruiser is offline   Reply With Quote
Old 03-28-2012, 10:44 PM   #11
100%Chevy
Looks like the winch under my Nissan.
Never thought to put one on my Chevies!
But,I will now!
Mike./
Old 03-29-2012, 12:26 PM   #12
k1rodeoboater
But,I will now!
Mike./
If you do mount it up you will have to change your username lol
Old 03-29-2012, 03:34 PM   #13
Surfdaddy
Surfdaddy's Avatar
That looks like a better way than the factory mount, as long as you can get to the crank. I had something similar on my cab over Ford many years ago, but it was a winch type with a roller. The crank was on the driver’s side near the bumper and the cable went to the center where a block or roller guided the cable pick up the tire. Worked very well and picked up the 11.50 16.5 wheel easily
Past projects:
1966 Caprice 2dr
1970 VW Squareback
Old 03-29-2012, 07:33 PM   #14
100%Chevy
O.K.,I'll get a winch from a 89/98 or so Chevy truck!
Got one on my 95 that looks like it will work.
Mike./
Old 03-29-2012, 07:46 PM   #15
k1rodeoboater
another idea I've seen for fleetside beds is to get another wheel tub, and invert it rightin front of the one in the bed. Obviously you'll have to cut your wood to make it fit, but it cradles the spare, and you can use a mount similar to the in bed fleetside mount, except the wheel will be down lower so it doesn't obscure your view as much.
