Sheetmetal Psycho
Wrapping headers
Looks like I'm in need of wrapping the headers since they appear to be making it too hot for the starter. Anyone have particular brands to avoid?
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up! Project "Rigginstine's Monster" 1971 C-10 longbed 355/4spd Future mods: 67 front clip Webby's Rigginations - where everything has potential! |
Re: Wrapping headers
Wrapping headers on a drag car/truck that only runs for short duration is ok but on a daily driver...don't know about that. I have heard not so great things about what it can do to your headers over time. It will hold moisture as well as heat...not good. Have you installed a heat shield?
#3 | |
heat shields, ceramic headers,and mini-starters are all things to help the problem
wraps rust out headers in everyday drivin and are quite ugly
Just put a heat shield on your starter like RexDodge mentioned, I have one and mine works.
1968 4x4 Frame, with a 67 Cab and Bed A Shorter Step 1999 Dodge 2500 Cummins Diesel |
Sheetmetal Psycho
I have a cover on the starter. I never heard of the wraps rusting out headers. Good to know. I need to take the header off to assess the starter wrap and double check the wiring. Thanks for the heads up guys.
is somthing that gets that hot going to hold moisture and used every day. I would think it would keep dry used every day
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
![]() Join Date: May 2007
I have seen wrapped headers on a dd, that were unwrapped after 2 years, and the tubes had pretty much turned to dust. It is the extreme heat cycles that kill the tubes. Just like the single wall stove pipe, on a wood burning stove.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Senior Moment
![]() Join Date: Mar 2002
I had the same problem. I went with a mini starter and then wraped it with a heat blanket that I bought at the parts store. Been at least 2 years now and NO problems what so ever
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Sheetmetal Psycho
I have one of those blankets around the starter right now. Doesn't mean it is covering it properly right now though.
#11 | ||
"I ain't nobody, dork."
You can also run a remote solenoid up on the inner fender too.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
All the major header manufactures void the warranty of wrapped headers.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#13 |
So,, what else you got???
![]() Join Date: May 2010
Check this starter out, might solve all your problems. We all run them around here. Napa # 246-5110.
#14 |
I wrapped a set of steel powdercoated Hedman headers on my Blazer and it destroyed the headers. Not from rust, but from not letting the headers dissipate the heat. The result is exteremely brittle steel. I ended up blowing out a hole in my number 6 tube, so I removed all of the wrap to see what was going on. The steel was so brittle that I could hit it with a hammer and break off pieces around the hole.
Go with a remote solenoid and never look back. |
#15 |
coat the headers, wrap the starter
#16 |
Sheetmetal Psycho
Is a remote solenoid something I can make out of the original or something I will have to buy seperately? I only ask since the starter is pretty new. I used a new solenoid off the starter I had before on my old cub cadet. Yup I'm a little bit redneck
