Old 03-28-2012, 12:41 AM   #1
Dads Burb
S10 Gas Tank?
Anyone using the gas tank from a mid 90's (1995) S10 Blazer 2 door. These are different from the S10 pickup tanks which appear to be a saddle tank arrangement. I have a 55 (2) suburban and the saddle tank would be great, but I don't think it would fit where the stock tank is.
I have seen a couple of the Blazer tanks mounted in the rear where the spare tire would be. I am installing a 5.3 and am thinking I can install a Walbro 255 in tank pump on the S10 sending unit. Anyone know if this is true?
Dads Burb is offline   Reply With Quote
Old 03-30-2012, 01:48 AM   #2
55dude
55dude's Avatar
Re: S10 Gas Tank?
leave the stock tank if your using the stock dash and just use a inline electric fuel pump, much less headaches.
55dude is offline   Reply With Quote
Old 03-30-2012, 10:34 AM   #3
Dads Burb
Re: S10 Gas Tank?
Thought about that, but don't want to put up with the noise of an external pump, and the stock tank is a saddle type and without it I have more room for exhaust system.
Old 03-30-2012, 02:46 PM   #4
91blkstpsd
91blkstpsd's Avatar
Re: S10 Gas Tank?
Im looking to do this as well on my 57 3100. Went to the yard yesterday and all they had were 4 dr Blazer that had the side tank. Lot of guy on the 88-98 boards use the Blazer tanks cause its an easy fit and hook up. Im also planning a 5.3 so I'll post up some pics once I run across one.
91blkstpsd is offline   Reply With Quote
Old 03-30-2012, 03:34 PM   #5
Dads Burb
Re: S10 Gas Tank?
What are you going to use for a fuel pump? I think they changed pump styles in 96 on the S10's. I was looking at a 95 S10 fuel tank and then modify the existing pump with the Walbro 255. The 96 and newer pumps are the bucket style.
I was going to get a used tank, but Rockauto.com has the 2 door tanks new for as low as $70.
Old 03-30-2012, 07:27 PM   #6
_Ogre
_Ogre's Avatar
Re: S10 Gas Tank?
when do we get to see a dads burb build thread???
we need pics
shop air compressor timer
Old 03-31-2012, 08:50 PM   #7
Dads Burb
Re: S10 Gas Tank?
With the way this project is going my grand kids may be finishing it.
Old 04-01-2012, 10:52 AM   #8
yoder
Re: S10 Gas Tank?
I used the 2dr blazer tank with my 5.3. Just made straps out of steel and welded in a crossmember in front of it. 25 bucks for a tank with pump and level sensor at the salvage yard.
yoder is offline   Reply With Quote
Old 04-02-2012, 10:37 AM   #9
Dads Burb
Re: S10 Gas Tank?
Yoder, do you know what year the blazer was? Did it have the bucket type pump?
Old 04-02-2012, 10:49 AM   #10
yoder
Re: S10 Gas Tank?
95. Non bucket type.
