Old 03-28-2012, 10:13 AM   #1
ScottH
ScottH's Avatar
Fresh 350 sbc engine cheap
I have a fresh 350 engine that I am not going to use for sale.
The short block has been completely rebuilt, zero miles on it.
Heads are from a 305 with 1.94 valves and some light porting done.
Engine just needs ur choice of cam, gaskets, and accessories.
Comes with a set of mis-matched shortie headers and mini starter.
First person with $500 gets it.
Any questions pls LMK.
Scott
1963 C10 swb fleetside
1966 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 03-28-2012, 10:48 AM   #2
Bethewaz
Re: Fresh 350 sbc engine cheap
Do you have a casting number and date code?
Bethewaz is offline   Reply With Quote
Old 03-28-2012, 11:10 AM   #3
ScottH
ScottH's Avatar
Casting # is 3970010.....how do u find the date code?
Old 03-28-2012, 11:19 AM   #4
HotRod C/10
HotRod C/10's Avatar
right front of block should be a # stamped in, just infront of the passenger side head
Thats a good block with high nickel content.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 03-28-2012, 02:57 PM   #5
Bethewaz
Casting Date code is on the rear of the block on top (passenger side), kind of opposite the casting number. It should be smaller in size and will be a letter with a few numbers after it. for example: F122 (June 12 of 1972) This is the date the engine block was made.
DSALMAN described the location of the stamped VIN and/or date code w/ engine suffix code (which tells you what it actually came in, date when that was determined, horsepower, transmission, 2 or 4 bolt main, etc. and is usually close to the assembly date of the vehicle).
In my case, I am interested specifically in the casting date code. Thanks!!
Old 03-28-2012, 10:33 PM   #6
ScottH
ScottH's Avatar
Got busy today and didnt get a chance to get it, but will tomorrow.
BTW I also have a 350 bare block I pulled from a 72 Cheyenne.
Scott
Old 03-29-2012, 10:10 AM   #7
ScottH
ScottH's Avatar
I looked at the block and there is no date code in that location.
Checked another block and found it just as u said, not sure why there isnt one on this motor.
Old 03-29-2012, 05:14 PM   #8
ScottH
ScottH's Avatar
ttt
Old 03-29-2012, 11:07 PM   #9
ScottH
ScottH's Avatar
must sell
Old 03-30-2012, 08:44 PM   #10
frednoah
86 Scottsdale
Wife would kill me if I brought home a motor, but I could use a mini starter. Any chance you'd want to separate?
frednoah is offline   Reply With Quote
Old 03-30-2012, 10:12 PM   #11
ScottH
ScottH's Avatar
Sorry its a package deal
Old 03-31-2012, 02:37 PM   #12
ScottH
ScottH's Avatar
ttt
Old 04-02-2012, 11:17 PM   #13
ScottH
ScottH's Avatar
ttt
Old 04-04-2012, 09:39 AM   #14
ScottH
ScottH's Avatar
ttt
Old 04-04-2012, 08:21 PM   #15
MidLifer
MidLifer's Avatar
Scott - I am local and interested. PM me a number where I can call you.
MidLifer is offline   Reply With Quote
Old 04-04-2012, 10:16 PM   #16
ScottH
ScottH's Avatar
Jim, PM sent
Old 04-06-2012, 10:30 PM   #17
ScottH
ScottH's Avatar
ttt
Old 04-08-2012, 10:06 AM   #18
ScottH
ScottH's Avatar
will include a used 350 turbo trans......what a deal!
Old 04-15-2012, 11:05 PM   #19
ScottH
ScottH's Avatar
ttt
