English Chevy Owner
Another bolt size needed
Sorry guys, yet again I am struggling with finding a bolt size. Can anybody tell me what size the engine mount bolt (the big single one that goes from the tower on the frame to the rubber mount) is on a 69 350 SBC. I had to take the entire tower out to remove an old bracket whilst changing out my P/S pump at the weekend and the old motor mount bolt is looking pretty chewed up and the rubber is a little old and covered in paint overspray, so I am going to replace the mount and need a new bolt. I have found a good supplier for UNC bolts now in the UK but need to know what size it is.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
mount bolt
will check the length today. it is a 5/8th dia, but don't know length off hand. you could measure the length. why not just use metric? everthing over here is going to that.
troy wilson |
It is a 7/16-14x1 1/4" long. You may have to go with 1 1/2" and use spacers or use a 1".
Jim |
Fabricate till you "puke"
7/16 -14 NC thread......not sure on the lenght, but close to 1 ". 5/8 is the head size of the bolt.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
English Chevy Owner
Thanks for the info guys, as speedy and helpful as ever. Troylv, I try to keep with original spec bolts as much as possible as it's a royal pain having a mixture of metric/imperial bolts. Also this goes into a captive nut so it has to be right.
![]() Join Date: Sep 2001
Make sure you buy a grade that matches the grade in the stock bolt, or something that won't cause damage to your mount over time. You don't want your bolt to be harder than the threads in the mount or the bracket, or you'll end up with the same problem I have: a loose mount that allows my fan to bang against my fan shroud on right turns.
![]() 0 marks: 2-grade 3 marks: 5-grade 6 marks: 8-grade stainless: ~5-grade I'd go with either stainless or 5 grade. It's a bit more ductile than 8-grade, and will flex a bit with the movement of the mount due to cyclic loading. Just some Materials Engineering for the day.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
Re: Another bolt size needed
Does anyone know the bolt or screw size that holds the parking brake bracket to the dash for support. Without the bracket bolted every time brake is applied the bracket moves / wiggles. Thanks in advance....Mike
#8 | |
Carpe manana
![]() ![]() Join Date: Dec 2010
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Thanks deadhead, found one laying around, Solid again.....Mike
Just in case someone stumbles across this thread searching for keywords, a quite note on the reproduction of the 1970 big block mounts out there:
- The center bolt is METRIC - The center bolt is TOO LONG and needs to be cut down lest it poke the block
#11 | |
