Old 03-28-2012, 01:21 PM   #1
Dieselholic92
Dieselholic92's Avatar
Brake Lines
So I'm finally going to have some time to work on my pickup this weekend. I still have one brake line to replace before I can bleed the brakes. Unfortunately, It's the long line on the frame that splices at the transmission and runs all the way back to the rubber brake line for the rear end. So do I have to buy a roll of brake line, straighten it, flare it, bend it and everything myself? Or do you guys know of an online source where I can get the whole line? I checked at napa, and o'reilly's and neither of them have a straight, pre-made piece long enough.
Semi professional heavy equipment operator
Amateur mechanic
Dieselholic92 is offline   Reply With Quote
Old 03-28-2012, 03:10 PM   #2
dv8customs
dv8customs's Avatar
Re: Brake Lines
You can get prebent lines from LMC and Brothers
dv8customs is offline   Reply With Quote
Old 03-28-2012, 03:57 PM   #3
crewcabshorty
crewcabshorty's Avatar
Re: Brake Lines
i have gotten several sets and pieces off of inline tube ,they make stainless and steel lines ,
crewcabshorty is offline   Reply With Quote
Old 03-28-2012, 04:28 PM   #4
chrismoore701
chrismoore701's Avatar
Re: Brake Lines
bought straight pieces at the local auto parts shop and put them next to the original line and bent to match for a fraction of the cost. key is a decent plier style bender
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 03-28-2012, 09:09 PM   #5
Dieselholic92
Re: Brake Lines
Okay I see the ones on LMC now. The brake line I need they only have in a 2wd half ton. Is it going to matter on my 4wd 3/4 ton?
Amateur mechanic
Old 03-28-2012, 09:13 PM   #6
Dieselholic92
Re: Brake Lines
Never mind I found the right ones on Brothers. Thanks guys
Amateur mechanic
