Old 03-28-2012, 02:37 PM   #1
K5Custom
1990 Suburban 2500 for 4wd to 2wd reference
Is there any difference in the the 2wd suspension from a 2500 Suburban that will hinder me from using it as reference for a 4wd to 2wd conversion on a 86 Jimmy? I plan on installing a Porterbuilt dropmember and components in the Jimmy so i wont actually use anything off of the Suburban, just need it for measurements.
K5Custom is offline   Reply With Quote
Old 03-28-2012, 05:27 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: 1990 Suburban 2500 for 4wd to 2wd reference
If you are planning on doing a 1/2 ton Blazer then I would say "yes".
The 3/4 ton 2wd suspension and the 1/2 ton 2wd suspension are entirely different animals.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-28-2012, 06:49 PM   #3
K5Custom
But I can use the burb to get the measurements I need?
Old 03-29-2012, 06:46 AM   #4
Keith Seymore
I would say no. I wouldn't trust it enough to make any committing decisions.
They're both 2wd - that's where the similarity ends.
Different frames, different crossmembers, different A arms, different brake sizes, different packaging, etc.
K
1979-1986
1986 - 2019
Old 03-29-2012, 11:35 AM   #5
K5Custom
Ok, thanks.
Old 04-13-2012, 11:57 AM   #6
manimal
manimal's Avatar
K
cant you just swap lower control arms,spindles,brakes between the two to have one or the other?
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 04-15-2012, 10:51 AM   #7
Keith Seymore
I don't think so.
I could be wrong but I think the frame shape and control arm attaching points are different between the two.
K
1979-1986
1986 - 2019
