Old 03-28-2012, 03:30 PM   #1
TJBrown
TJBrown's Avatar
Seam Sealer in the Bed question
i have noticed that the seam sealer in the bed is cracked and hell, lets me honest, coming loose. What is the correct stuff to use on this. I ma looking to remove all the existing sealer and start all over before lining the bed.
T
85 Silverado SWB
TJBrown is offline   Reply With Quote
Old 03-28-2012, 04:05 PM   #2
86c20
86c20's Avatar
Re: Seam Sealer in the Bed question
i belive that 3m makes a seem sealer and there is a bursh on and i think one for a gun too
86c20 is offline   Reply With Quote
Old 03-28-2012, 04:27 PM   #3
bigsj
bigsj's Avatar
That was a good question i am getting ready to do the same thing let me no how it turns out and which brand you use.With some pics if you take some.
bigsj is offline   Reply With Quote
Old 03-28-2012, 04:36 PM   #4
crewcabsquared
I have done several. Clean out all the old caulk, wire brush or grind any rust out in the seams, and apply a rust sealing paint to the seams. Then reapply the seam sealer (3m fast n firm and Crest qwik-seam are both good). I prefer the type that uses a caulk gun for these areas. You can use paint thinner on a small brush to smooth any areas needed (or wax and grease remover). Hope this helps.
Steve
crewcabsquared is offline   Reply With Quote
Old 03-28-2012, 04:37 PM   #5
67swb72klb
67swb72klb's Avatar
u must have used some type of laytex sealer i use 3m ultra pro it is a urathane stays flexible and sticks very well still good on my box must be goin on 17-18 years
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 03-28-2012, 07:34 PM   #6
FLEETSIDE MIKE
A guy at work was patching his floor in a 69 nova & got a tube from O'Reilley Auto Parts,Expensive but works great. It was a tube like for a caulk gun & went a long way...
Hope this helps
Mike
1985 SWB Silverado
355 ci 375hp+ (installing)
700r4 (installing)
FLEETSIDE MIKE is offline   Reply With Quote
