1963 chevrolet 1/2 ton v8 radiator
hi,does anyone have a picture of the lower radiator mounts/location ??? i have purchased 2 radiators supposedly for a v8 and neither seems to fit or mount right,does the v8 rad sit down low in those saddles or up on that step and are there different upper brackets for a v8 ??? yes i know the 6 is different but is there more than 1 v8 bracket ?? i need help and pictures if possible,thanks to all who may help......
Enjoy your truck
Re: 1963 chevrolet 1/2 ton v8 radiator
I just swapped out my rad a couple of weeks ago - a 3 core for a 4 core - and I could have taken some pictures for you if I had known.
I am using the 6 cyl brackets on my v8 rad. I cut them to accomodate the thicker tank on the v8 - just made a wider base for the rad to sit in. I didn't have a pair of v8 brackets several years ago when I put in the 3 core. Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
do you have to move the radiator up to that higher lip ??
i just got a supposedly correct 4 core radiator and it will not fit down in between the frame rails
I had to move mine up to the top step and closer to the rad support. I made my own brackets top/bottom. This thread has some pics. They might help.
http://67-72chevytrucks.com/vboard/s...29#post4826129 |
Enjoy your truck
I don't recall if I did or didn't.
I know I did get a proper v8 hold down bracket which is higher than the 6 cyl bracket. Greg.
The 4 core radiator, which has about a 2 5/8" width core, uses a wider top mounting bracket and lower mounting. If I remember right about 1/4 to 3/8 wider than the 3 core V8 radiator. I don't know if the 6 is smaller yet than the 3 core V8 radiator.
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
60-66 Nut
![]() ![]() Join Date: Mar 2007
The V8 radiators sit on top of the crossmember below the radiator support, not down between the frame rails. You will need a different upper support than what is used with the smaller 6 cyl radiator. Send me a pm if you need one for either a 3 row core or a 4 row core.
