03-28-2012, 11:16 PM | #1 |
1/4" brake line - Bulkhead fitting?
Got to re-route my line that feeds the rear brakes, I have to pass through
the frame (not boxed). Is there an inverted flare fitting for this purpose, or do I have to convert to AN and back again? Cheers RW
69 396BB Turbo 400 Fleetside, 3:07 Gears 2.5" & 4" drop 2020 Silverado 2500LT 2006 Subaru Forester 2019 Chevy Cruze |
03-28-2012, 11:31 PM | #2 |
Re: 1/4" brake line - Bulkhead fitting?
Yeah most auto parts store have them as a stock item.
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
03-29-2012, 03:05 AM | #3 |
Is it a bulkhead fitting or something else?
RW
03-29-2012, 07:55 AM | #4 |
I just ask for brake fittings whether it be a t, 4 way, coupling, ect and they have always had the inverted flare on the inside so that they wouldnt leak....
03-29-2012, 09:08 AM | #5 |
I have never seen a brake line fitting made for bulkheads and NAPA does not carry them or have access to one. I suspect that converting to AN is going to be your option.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
03-29-2012, 09:48 AM | #6 |
get a speedway motors catalogue(free)// loads of bulkhead fittings available of all sorts for custom plumbing of brake lines// no need to convert to AN fittings
03-29-2012, 10:57 AM | #7 | |
Spanked once
http://67-72chevytrucks.com/vboard/s...5&postcount=48
The ole 350 budget build. |
03-29-2012, 10:50 PM | #8 |
FyI all, I found a company called Swagelok. They have fittings for metal tube
high pressure (like say 60,000lbs/in.), made for aerospace and nuclear plants etc. Plan to head there tomorrow. Heres the link http://www.swagelok.com/ RW
03-29-2012, 11:21 PM | #9 |
I have used inlinetube.com quite a bit, and have been very satisfied with their products and service.
03-30-2012, 10:24 PM | #10 | |
Went to Swagelok today. They have fittings for various tubing sizes, elbows, T's etc. Stainless Steel or Brass, high pressure. No flaring required - they have a double-ferrule design that clamps the tubing. Adaptors for changing tube sizes too.
