Old 03-29-2012, 07:56 AM   #1
hrc200x
Any tips to fixing stripped drip rail and wheel arch moulding holes
As I'm piecing together my truck I've found 3 drip rail and 6 wheel arch holes that are stripped. Any tips to fixing these?
I ordered the wheel arch trim from LMC so all the screws match and it would be nice to leave it that way, otherwise I could go to a bigger size.
Of course truck is already painted so welding closed and redrilling isn't an option.
Also any tricks to installing the drip rail trim? Seems there isn't enough room between the trim and bolt head to get it started easily, fitting a socket on it is impossible and I don't have a wrench small enough. They must have changed head sizes from 83/84ish to 85?
Thanks.
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208.
hrc200x is offline   Reply With Quote
Old 03-29-2012, 08:30 AM   #2
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: Any tips to fixing stripped drip rail and wheel arch moulding holes
All I got is welding up the holes, so I'd be interested in hear some other options if there are any.
I believe the chrome trim on the drip rail comes off. Underneath, the drip rail has grooves cut out to allow sockets to be used. It's shows it on this page from LMC
2020 Silverado Trail Boss - 6.2/10spd
Dalaigh is offline   Reply With Quote
Old 03-29-2012, 08:36 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
IMHO anything else that was put in the holes to give you a little more room would help retain moisture and then assist in that evil rust.. you could see if you could cut up one of those plastic nylon mollys used in sheetrock and see if you could make up some room with that but IMHO it would provide a place for small amouns of road salt and dirt to hide
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-29-2012, 09:03 AM   #4
100%Chevy
Try putting a strand of copper wire in the hole with the screw.
And,put some body putty in the holes too.
Mike./
100%Chevy is offline   Reply With Quote
Old 03-29-2012, 10:06 AM   #5
Eyegore
What Hump?
Eyegore's Avatar
Just use some silicone sealer that dries up, then you will make sure of no leaks and rust.
Tom
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 07-04-2013, 09:14 AM   #6
hrc200x
For future reference I ended up using flashing I had laying around, its the stuff you use on houses that come in widths and lengths such as 12"x10' rolls. I cut very small pieces maybe 3/16" wide and inch or so long, put that in the hole and threaded the bolt in and it seemed to tighten up. I only did the drip rails, havn't tried yet on the wheel arch but don't see why it wouldn't work.
Old 07-05-2013, 01:50 AM   #7
andrewmp6
Use a rivnut its like a rivet but has threads in the hole so you can use a screw in it.
andrewmp6 is offline   Reply With Quote
Old 07-05-2013, 02:23 AM   #8
franken
The next size up screw?
franken is offline   Reply With Quote
Old 07-05-2013, 02:46 AM   #9
Remon.
Remon.'s Avatar
X2. This is the best way to go
Remon. is offline   Reply With Quote
