Old 03-29-2012, 08:15 AM   #1
96duck
96duck's Avatar
Brake lights
Trying to get my 1964 Chevy back on the road for spring. After installing a new wiring harness and headlight switch my running lights and brake lights stopped working. I have checked all connections and installed new bulbs. Automotive wiring is not my thing so any suggestions would be helpful.
96duck is offline   Reply With Quote
Old 03-29-2012, 07:43 PM   #2
tincan1966
tincan1966's Avatar
Re: Brake lights
make sure you have a good ground at the tailights. Sometimes it helps to add a wires from the housing to the chassis.
tincan1966 is offline   Reply With Quote
Old 03-29-2012, 08:12 PM   #3
SS317
SS317's Avatar
Re: Brake lights
Yes.... This!!. I've found most of the electrical problems on my truck are from bad grounds.
1966 Chevy C-10
350 Engine
700R4
SS317 is offline   Reply With Quote
Old 03-29-2012, 08:25 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Brake lights
also check you brake light switch
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
