Old 03-29-2012, 12:46 PM   #1
elks
Need a new rear yoke... Help please!!!
So I am starting to go through rear straps on my 1972 chevy blazer. I know the rear is a 12 bolt, but I am wanting to upgrade from straps to u-bolt style. Local part houses, are of no help so I need to order online.
I need to know how many splines the pinyon shafts are. Also I know factory it came with a 1310 ujoint. Right now I have a 1 ton tom woods driveline. But am using a crossover rear ujoint. If I can I would like to take that ujoint to a full 1350. So anyone know what I need to get inorder to get away from straps and go to a 1350 ujoint?
My biggest hang up right now is the spline count.
Also I am aware that the set up uses a crush sleeve and what I need to do there...
Thanks a ton.
Confidence is the feeling we have before we fully comprehend the situation
elks is offline   Reply With Quote
Old 03-29-2012, 01:00 PM   #2
Ackattack
Ackattack's Avatar
Re: Need a new rear yoke... Help please!!!
I got mine off of ebay. It was a spicer unit (don't have the P/N with me) but I found this one as well
http://www.ebay.com/itm/12-Bolt-Chev...ht_1368wt_1222
Ackattack is offline   Reply With Quote
Old 03-29-2012, 02:18 PM   #3
elks
So it is 30 spline. Also what size is the pinyon nut? Socket size? Do they have a kit with a new pinyon nut included?
Would this one work even though it says its for a car?
http://www.ebay.com/itm/64-72-Chevy-...e3b33d&vxp=mtr
Old 03-29-2012, 02:37 PM   #4
Ackattack
Ackattack's Avatar
My kit came with the nut and washer as well. It may have even come with a new crush sleeve, I can't remember cause I rebuilt the whole rearend. I'd just message them and ask.
I've had different size pinion nuts in the range of 1-1/16 to 1-1/4.
Old 03-29-2012, 02:41 PM   #5
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I got mine from a driveshaft place.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 03-29-2012, 06:38 PM   #6
mmmBoost
I bought Moroso U Joint Girdles from Summit racing after I blew the caps off my rear yoke, sheering off the cap retainer nubs. Never had a problem since. and for $30 I couldn't beat it. I'll take a pic when I get home. Here's a link
http://www.summitracing.com/search/?...0girdles&dds=1
Always remember those that had your back
Never forget those that turned it
Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt,
Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner
mmmBoost is offline   Reply With Quote
Old 03-29-2012, 06:40 PM   #7
mmmBoost
They're super easy to install and you don't have to remove the yoke
Old 03-29-2012, 09:21 PM   #8
elks
I think part of my failure issue is front the yoke being wore out a touch. Is the pinion for the car same as the truck/blazer?
If so this should work...
Old 03-30-2012, 03:36 PM   #9
mmmBoost
Here'sthe pics of mine. Here you can see where the tab broke off mine.
I've had mine on for 11 yrs but spent 8 yrs sitting
Old 03-30-2012, 04:34 PM   #10
68shortfleet
I am also in need of this 1350 yoke for a 12 bolt.
Did GM use this on any factory applications?
68shortfleet is offline   Reply With Quote
