Old 03-29-2012, 05:17 PM   #1
ol_skool_chevy
ol_skool_chevy's Avatar
6 Lug spider Caps
I was calling around today looking to manufacturer 6 lugs spider caps but i needed someone to do the tooling and I talk to this guys at Hub Cap Mikes and he told me someone is making them as we speak. they will be available but july 2012 and sold in this site......About time
http://www.hubcapmike.com/contact_us.html
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 03-29-2012, 05:26 PM   #2
hopped up
hopped up's Avatar
Re: 6 Lug spider Caps
nice i may need to get sone of those
hopped up is offline   Reply With Quote
Old 03-30-2012, 12:09 AM   #3
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Great! Love the spider caps.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 03-30-2012, 10:51 PM   #4
NCD1966
NCD1966's Avatar
sweet i was just web searching for this today!
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
Old 03-30-2012, 11:33 PM   #5
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
I'm in need of a set
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 06-12-2012, 11:57 PM   #6
poncho_villa
poncho_villa's Avatar
I'm getting tired of looking and searching for these. Anybody have an opinion of these?
http://www.summitracing.com/parts/GOR-16/
Gorilla also makes the spinners that attach to these and they are found elsewhere on this site.
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
Old 06-13-2012, 10:51 AM   #7
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Are you trying to put these on GM 6 lug wheels? If so, there is no clearance for any push through type cap. If you look at the center hub and the center of the wheel when mounted, the hub contacts the wheel to help center it. There is zero room for a push through cap.
The exception to this is if you have converted to 6 lug discs in the front as the hub diameter is the smaller 5 lug style (since they used blank 5 lug type rotors). There was enough room for caps but then you would only have them on the front and not the rear.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-13-2012, 01:27 PM   #8
doobiebro
doobiebro's Avatar
Thanks for the info...I been wanting 6 lug spider caps for years and your right...no one makes them...
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 06-13-2012, 01:35 PM   #9
poncho_villa
Thanks for the insight Chevy_Mike. That is the kind of issues that needs to be discussed about these caps. I have aftermarket rotors on the front, so they would probably work there, but not the back. I suppose that I could mount the caps on the outside of the back wheel. I have a colorful adjective to describe how that would look. Plus I'm sure there would be issues with the lugnuts with that.
Old 06-13-2012, 01:40 PM   #10
poncho_villa
Here is their website for more info and shopping choices.
http://www.gorilla-auto.com/spinners
Old 06-13-2012, 02:28 PM   #11
losthope
losthope's Avatar
one option you can do is grind the center out and use the push thur caps and bullet lug nuts and make what they call a "poor mans" spider cap like i did in my build thread heres some pictures:
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 06-14-2012, 06:55 AM   #12
C-10cutty
C-10cutty's Avatar
That's the look I'm going for. Where did you find your caps and what size if you don't mind me asking?
C-10cutty is offline   Reply With Quote
Old 06-14-2012, 06:38 PM   #13
Malibob
Malibob's Avatar
That is AWSEOME. I like the look of the bullet centers and bullet lugs but there is just something special about a spider cap. I cant wait to see them.
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline   Reply With Quote
Old 06-14-2012, 11:06 PM   #14
losthope
losthope's Avatar
got them from http://lugnutking.com/ you have to grind a little out of the center of the wheel to get them to slide through , they measure 3.75"
I agree,I like the look of spider caps better!!
Timmy D.
Old 12-11-2012, 03:07 PM   #15
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
Any word on these yet??
Old 12-11-2012, 03:23 PM   #16
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Subscribed, I was looking for these a while back.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 12-11-2012, 03:29 PM   #17
poncho_villa
Same here. I'm still in the market for a set.
Old 12-12-2013, 12:26 PM   #18
jhama78
jhama78's Avatar
Back from the dead...
Whatd you use to open up the center holes in your wheels? Die grinder?
Im doing the same thing with my stock 67 wheels and the caps should be here this week.
Thanks in advance
-j-rod
Edit: Nevermind, I found it in your build thread.
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
