05-06-2003, 12:22 PM | #1 |
Saving 1 truck at a time!
HEI with sb in 6 hole?
This stinks...! I was having fun burning up the neighborhood and lost my spark...condensor, points, primary coil wire (18 kilo-ohms too high?), coil (11.5 kilo-ohms too high? book says 4-10 kilo-ohms)...anyway. I have a tested and working HEI and I am thinking just throw it in but my 283 is sitting in the I-6 (back) slot and it does not look like there is enough room to shoe horn it in there. Anyone running a sb in the 6 holes with an HEI? I don't really want to hammer the firewall to get it in.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
05-06-2003, 01:04 PM | #2 |
Yup, It's tight and almost impossible to get the cap on and off, but it's in there.
Silence is golden, duct tape is silver. - Scott |
05-06-2003, 01:22 PM | #3 |
gr8, does that mean I can install mine sans cap with the motor in place or do you know whether that can be done? Could be that the motor was installed with the dizzy already in place! I guess I could just try but I have so many pending projects that I am trying to minimize my efforts here so that I can be ready for the Monroe Swap Meet...May 17-18! You going to be there?
05-06-2003, 02:42 PM | #4 |
Recovering Truck Driver
Mine is VERY close to the firewall in my 4x4, but it does fit. I can take the cap off, but it's hard to get to and somewhat painful. About putting HEI on a 283, I ran into a problem when I tried it. The centering flanges (for lack of a better word) are in different spots between the old style blocks and the new style. My HEI wouldn't fit, it flopped around like a ducks @ss. If I remember right, the block was and early 60's block, so the later models might work with it.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
05-06-2003, 03:05 PM | #5 |
What if?
mine is also in the i6 spot. put the dist in then the cap.
have to use a short screw stick to get to the rear 2 hold downs though.
2002 red extended cab Silverado 2002 Wheatland yellow Suburban |
05-06-2003, 03:27 PM | #6 |
I just rebuilt mine. Its in the 6 spot. I climbed in and stood on the framerail. It still was a pain, but it can definitely be done.
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
05-06-2003, 03:53 PM | #7 |
Huck...now you got me worried! I might have to go back to points? I guess I should check the block number...probably easier to just shoe horn it in and see if it is going to work.
05-06-2003, 03:55 PM | #8 |
stllookn,
I thought I saw that MSD was making low profile distributor caps for HEI distributors. Would that make the situation easier? Not sure if it was only for V8s though. Brian |
05-06-2003, 04:29 PM | #9 |
I was able to change my intake manifold with the engine in place. That requires removal/installation of the distributor. Mine was an HEI 305, now it's a 350. I can still work on it. Good luck, Scott
05-06-2003, 04:54 PM | #10 |
gr8, Thanks. I will give it try but I am still a little worried about what Huck said about it flopping around. I have seen that recently with Orence1 and his MSD/big block install. Seems it is more frequent than some of us realize. I can always purchase the same bushing he did to solve the problem...LOL!
05-06-2003, 05:59 PM | #11 |
Location: Katy, TX...but the love of my life resides in Dublin,OH.
I had an HEI in a 283 in the 6 cylinder spot.... I didnt ever remove or install it. The 350 went back in in the 6 cyl spot and the HEI went back in several hundred times.... long story... but I did it without the cap and would put the cap on afterwards... stubby screwdriver....
05-06-2003, 06:26 PM | #12 |
Out of the carpool lane.
Stllookn, I've got an original uncut points wire for a six if you need it. Don't know if that would work for you even if you did, but the offers there.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
05-06-2003, 07:59 PM | #13 |
Fabricate till you "puke"
The HEI goes in & out in the I 6 position, with the cap & rotor off.....it does fit damn tight tho! I also have 1 1/2" on the longhorn& it still fits(no hammer work on the firewall)........crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
