03-29-2012, 07:14 PM | #1 |
what psi should i run my rear bags at
i just got done installing my D2600 air bags in the rear...what psi do i want to run them at? can i run them at any psi?
03-29-2012, 08:06 PM | #2 |
Square
Re: what psi should i rum my rear bags at
whatever psi it takes to get your truck to your ride height.
Squarebody Syndicate |
03-29-2012, 09:18 PM | #3 |
so anything i want? can i run them without air?
03-29-2012, 09:34 PM | #4 |
03-29-2012, 11:20 PM | #5 |
Not enough air = bouncy ride.
Too much air = stiff ride. For that size bag mounted in the stock coil location in a truck-arm arrangement, the min is prob about 30psi up to about 60psi.
03-29-2012, 11:20 PM | #6 |
cool thanx
03-30-2012, 01:20 AM | #7 |
It just depends on a ton of things just put them in and play with it tell your happy.
03-30-2012, 10:22 AM | #8 |
but i cant run them aired out?
03-30-2012, 10:34 AM | #9 |
Happy to be here
You might be able to run them with no air, but its not good advice. With little or no air in them, they are prone to chaffing against themselves. You never want the bag to come in contact with anything as it will lead to failure.
Beyond that, it will ride like a buckboard and you will look foolish bouncing down the road.
03-30-2012, 11:22 AM | #10 |
Would you drive down the road w/a flat tire? Why would you want to drive around w/no air in the bags?
03-30-2012, 11:50 AM | #11 |
PITbut
My truck 71 stepside, rides the best at 30psi in the rear and 70 psi in the front. any more or any less and its a bump fest.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
04-03-2012, 02:23 PM | #12 |
Junior Member
lyrikz, You running D2600's also? What is your rear bag height at 30psi?
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
04-03-2012, 03:07 PM | #13 |
PITbut
No, im not running d2600's sorry.. Running firestones or something i think.
