Old 03-29-2012, 09:36 PM   #1
Square_78
Square_78's Avatar
driveshaft banging noise after flip kit install
Got my flip kit in my 78 c10 today... came down a LOT. wow like 8 inches after i took out a few leafs. I left in 4 leafs plus the overload. Its the summit racing kit with the little red bumpstop. The axel is about 1" from the bumpstop. Anyways, now when i give it light acceleration, theres a bang bang bang that i assume is the driveshaft. U-joint angles? Has anyone else had this problem? If the truck is coasting in gear there is no noise. If you give it gas then BANG BANG BANG. Not good.
Ive read something about the carrier bearing. If the mount adjustable?
Any ideas???
I cant even drive the thing the way it is.
Square_78 is offline   Reply With Quote
Old 03-29-2012, 09:39 PM   #2
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: driveshaft banging noise after flip kit install
Two piece or one piece drive shaft?
Did you flip kit come with shims to correct pinion angel? Could be out, at least that what it sounds like to me.
2020 Silverado Trail Boss - 6.2/10spd
Dalaigh is offline   Reply With Quote
Old 03-29-2012, 09:48 PM   #3
Square_78
Square_78's Avatar
two piece shaft. No shims in the kit
Old 03-29-2012, 09:53 PM   #4
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Being that you've lowered the truck so much you probably need shims to get the pinion angel set right again. Though because it's a two piece it shouldn't be out bad, not as bad as it would if it were a one piece.
Old 03-29-2012, 10:05 PM   #5
Square_78
Square_78's Avatar
OK so hopefully my friends shop can fix it tomorrow if its a somewhat normal adjustment...
Old 03-29-2012, 10:21 PM   #6
Square_78
Square_78's Avatar
It came down a lot in the back... I have air shocks ordered. They will be in next week so i will have some adjustment.
Hopefully my shop can fix the drive shaft issue...
Old 03-29-2012, 10:25 PM   #7
cory d
cory d's Avatar
the dirrections in my kit suggest swapping out the 2 piece for a 1 piece. i didnt, i just adjusted he height of the bearing to correct te angle and its all pretty straight now, better then it was stock.
i love your truck with rust, dents adn all
cory d is offline   Reply With Quote
Old 03-29-2012, 10:28 PM   #8
Square_78
Square_78's Avatar
How do you adjust the carrier bearing? is it adjustable or do you have to cut it off and re-weld it?
Old 03-29-2012, 10:32 PM   #9
Dalaigh
Canadian Trucker
Dalaigh's Avatar
The adjustment for the carrier is just a spacer and longer bolts.
Old 03-29-2012, 10:35 PM   #10
Square_78
Square_78's Avatar
OK cool. Thanks for the info. I can relax a little now I guess.
Old 03-30-2012, 12:13 AM   #11
the_ocho
did your flip kit relocate the axle back at all? it could be that with the drop its causing your drive shaft to bottom out on one of the slip yokes. most likely its the one at the carrier but it could be at the tranny to. just something to check.
the_ocho is offline   Reply With Quote
Old 03-30-2012, 01:37 AM   #12
Square_78
Square_78's Avatar
Yes the flip bracket had the off center hole that pulls the axel back around an inch or so.
Old 03-30-2012, 05:02 AM   #13
Square_78
Square_78's Avatar
Do I need to raise the bearing up, or lower it? Im looking online and getting all sorts of answers and none of them are the same.
Old 03-30-2012, 06:38 AM   #14
J Knight
J Knight's Avatar
You need to move the carrier bearing up.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 03-30-2012, 04:19 PM   #15
Square_78
Square_78's Avatar
OK. Its going in this afternoon. I have a shim kit for the rear diff also incase they need it. I cant wait to actually drive it!
Old 03-30-2012, 04:29 PM   #16
hopped up
hopped up's Avatar
sounds to me like the front of the rearend is huyting the floor. when you step kn the gas the angle goes up a little may be pointing up already cuz if the drop.
hopped up is offline   Reply With Quote
Old 03-30-2012, 04:30 PM   #17
hopped up
hopped up's Avatar
sounds to me like the front of the rearend is hitting the floor. when you step on the gas the angle goes up a little may be pointing up already cuz if the drop.
Old 03-30-2012, 04:42 PM   #18
Square_78
Square_78's Avatar
I dont think its hitting the floor. Theres lot of room. It will hit the bumpstops before that happens. Theres about 1" between the rear end and the bumpstops right now. If you are in gear and coasting, there is no noise. As soon as you lightly tough the throttle, it starts banging. I think its just lowered too much. When you touch the gas, the rear end probably drops a little and that put the alignment out just enough to cause the noise. Its not a single bang. Its a bang bang bang bang bang. Sounds like everytime the driveshaft rotates, its makes a bang. As you step on the gas, the banging gets faster so its consistant with the driveshaft rotation.
Old 03-30-2012, 05:17 PM   #19
cory d
cory d's Avatar
the angle could be off causing it to vibrate. it the carrier bearing is loose that could cause the noise
Old 03-30-2012, 05:33 PM   #20
Square_78
Square_78's Avatar
oh ok so the carrier bearing itself could be making the bang bang bang noise also. I just assumed it was the U-joints. Its an old beater truck so anything is possible. I just want to be able to go into the shop with as much info as I can to help them. They dont work on many lowered trucks. I hope this doesnt get too expensive.
Old 03-30-2012, 10:48 PM   #21
boatpuller
boatpuller's Avatar
i betcha if you crawl under there and look .....i think you'll see some screwed up angles with your drive line.here's a pic of what i did.you need to raise the bearing up towards the floor.we cut off the bracket then welded in a flat piece then bolted the bearing to the new piece.that results in a straight angled shaft...it's been flawless for 4 years now.good luck.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 03-31-2012, 08:12 AM   #22
Square_78
Square_78's Avatar
Good pic thankyou. I'll show that to the guy at the shop!
we put a 4 degree shim in the back today and the banging is gone, but there is still lots of vibrating.
Old 06-17-2012, 03:42 PM   #23
Ford Assassin
Ford Assassin's Avatar
What air shock part number did you go with? I need some with about 18-20" extended length.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 06-17-2012, 06:11 PM   #24
Square_78
Square_78's Avatar
I have no idea. I gave the guy the length between the mounts at ride height and he ordered them for me. I do have the shock entension brackets installed also.
Old 06-17-2012, 06:15 PM   #25
Ford Assassin
What 'guy'?
Thanks.
Cable
