What old cars/trucks came with 15" steering wheel?
I'm wanting to swap the steering wheel rim for a smaller 15" OD rim on my '66 deluxe wheel. I know it's not common but I want to cut the two rims apart where the spokes meets the rims, then weld the smaller rim on the original '66 wheel. The area where the spokes meet will be filled in with epoxy and shaped to match the original profile. I'll post a detailed how-to once I find a donor wheel. My question is, what old car or truck had a 15" outside diameter steering wheel with grips that are similar to the original '66 truck wheel? Thanks in advance!
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Re: What old cars/trucks came with 15" steering wheel?
Btw, I'll have power steering and a quicker ratio steering box so I won't need the extra leverage of the larger factory wheel. The '66 deluxe wheel measures 16 3/8" OD.
1961 crewcab
camaro/chevelle I think had a smaller wheel 69-72
how about an early corvair?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Maybe nova II's
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
I had wondered about a Corvair wheel since they didn't have much weight on the front. I pulled out one of my extra mid-60's VW Bug wheels and it was just barely smaller. I thought it funny that a rear engine 1,600 pound VW had basicly the same size wheel as a 3500+ front engine, non-power steering truck.
Artist
![]() Join Date: Jan 2010
Ill ask my Corvair buddy... he should know...
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66 |
![]() Join Date: May 2007
Interesting to see.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
I had some time today to spend on the wheel. I decided to go ahead and try shrinking the original rim down to 15" instead of swapping rims. There was going to be alot of cutting, fitting, welding, epoxying, sanding, and shaping anyways, so why not do it the hard way? Beats waiting on finding a 15" rim...
Here's the short version, I'll start a how-to thread if you guys are interested in seeing the whole process. The original '66 deluxe wheel. ![]() Cut marks. ![]() After cutting. ![]() Marking the spokes for the cut. I've got a plan in mind that I think will make remaking the tapered end of the dimpled indention pretty simple when it's time to start epoxying and reshaping the wheel. ![]() Spokes shortened, super glued in place temporarily for mock up purposes. ![]() First mock up (after also shorting the two pieces of the rim). To get the hub centered, the edges of the rim and spokes on one side didn't meet up. I shortened one edge and will have to lengthen the other. ![]() After getting everything roughly in the right position and the center hub centered in the rim, using one of the cut pieces to fill in the gap. ![]() ![]() Roughed in and ready to start grinding back the plastic to weld the rim in place. It measures 15 inches now. I'll grind the edges back and glass bead the old paint and grime off, then use the steering shaft with a level and make sure the hub is level and centered, and 90* to the rim before welding the rim back together. I'll post pics once I get all that done. ![]() ![]()
Artist
Nice!
Thanks!!
Worked on it some more tonight. I got the plastic stripped back and the steel rim ends cleaned, aligned and welded. Then the cracks in the plastic were ground out all the way to the steel core to prevent them from showing up later. I also blasted around the cracked area so the epoxy would have a clean and textured surface to bond to. I'll start building up the epoxy tomorrow. ![]() ![]() ![]() ![]() Posted via Mobile Device
Ok, so I won't be doing a "how-to" thread on this. I don't want anybody to go out and do this, because they think its a great idea- because it isn't! There's a reason guys do rim swaps instead of using the existing rim; its a ton more work! With that said, here are the progress pics to keep you guys up to date. I'll post the pics to show what has went into this, and hopefully the amount of work involved will scare you guys away from attempting this yourself!
Epoxy applied in the cracks and joints. ![]() ![]() ![]() Overall shape compared to an original wheel. ![]() Sanding the epoxy smooth. Sanding isn't really the right word, it's more like sculpting with sandpaper. My fingertips hate me... ![]() ![]() ![]() ![]() ![]()
Artist
Awesome!
#13 |
Update for anyone following along. I finished shaping the wheel repairs and sprayed it with a couple thick coats of Slick Sand. I did spray a light coat of Bull Dog adhesion promoter over the wheel first to help make sure the primer sticks. The textured recessed area was masked off so the primer didn't smooth out the grain.
#14 |
It's Better With Nitro
Very cool! Nice work...that was a lot of sanding.
#15 |
Impressive!
79 Blazer 350 TH350 part time 4wd Sold! 86 GMC 1 ton something... |
#16 |
1 thing at a time is progress.
Very impressive!!
Alan
Philippians 2:14-16 |
#17 |
Thanks dudes! vin63, I did use an extended nose die grinder with an oval shape carbide burr to do the rough shaping on the places where I gooped on too much epoxy. Still was a ton of sanding though, and I've still gotta sand the Slick Sand. ![]()
#18 |
Early 60's Impala's also had 15" wheels.
#19 |
Could you tell me what kind of epoxy you used? Does it have a brand name? Thanks
#20 | |
#21 |
awesome write up! thanks!! looks great!!
#22 |
You realize this thread had gone silent over 4 years ago, right?
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
#23 |
...I hear that alot...but when you use the forum for help using the search feature, the date and time aren't any of my priority concerns... I'm happy to see these dinosaur threads still hang around! If it offends anyone that I bring them back from the dead...please pm me
#24 |
It's better than starting a new one, then someone posting the link to the old one, and both of them ending up at the top. Nothing wrong with searching and replying to old threads.
#25 |
It's not like it's an old for sale thread. Old threads remain as a permanent resource, which is what makes this site so great. I keep old magazines for the same reason, not just for the cover picture. Think of this website as a library for our trucks and you will understand
