Old 03-30-2012, 01:26 AM   #1
c10seconds
c10seconds's Avatar
Fuel filters/pumps mounting locations
Trying to figure out where to mount my external pump and filters.
Aeromotive recommends mounting the pump below the tank but I dont see that being possible with my set up. Anybody have pics or ideas? Im wanting to mount everything on the rear most frame support xmember right behind the rear bumper. Would this be ok? Im using a boyds rear mount tank
c10seconds is offline   Reply With Quote
Old 03-30-2012, 09:36 AM   #2
Shon
Re: Fuel filters/pumps mounting locations
Most will mount external pumps on the frame rail.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 03-31-2012, 12:54 AM   #3
66ChevyMax
66ChevyMax's Avatar
I have a internal pump. Here is my filter/reg.
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 03-31-2012, 04:18 PM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Mine is on the frame as close to the tank as possible. Just hit 1200 miles, no problems so far..
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-21-2012, 09:45 PM   #5
BigShoe24
True Addiction
BigShoe24's Avatar
Guys,
If I am going to run an external Walbro with a vette filter/reg does it matter which side my pump is on? Does it have to be before the regulator, or can the pump be between the regulator and the fuel rail. I would think it need to be between the fuel cell and regulator, but it would be nice to get the benefit of the filter on the pump. Thanks
RCC
BigShoe24 is offline   Reply With Quote
Old 04-21-2012, 11:50 PM   #6
c10seconds
c10seconds's Avatar
This is how I mounted mine. Feed is on the passenger side. Regulator is after the fuel rails
Old 04-22-2012, 08:25 AM   #7
BigShoe24
True Addiction
BigShoe24's Avatar
c10, thanks. I'm going to believe it's best to run the pump inline between the fuel cell and the filter/regulator. Thanks again.
RCC
Old 04-22-2012, 08:44 AM   #8
Nova_Cobra64
Nova_Cobra64's Avatar
Definately run the vette filter/reg after the pump as it brings the pressure down to the proper pressure for the fuel system. If you want a filter before the pump just run a cheap filter.
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 04-22-2012, 09:13 PM   #9
rmvlt1100
rmvlt1100's Avatar
I made a bracket for my pump that hangs in front of the fuel tank and I used an Aeromotive filter that connects to a 90 degree fitting that connects to the discharge port of the fuel tank. I think my pump is only about 1" above the outlet. I'm at work so I can post a picture tomorrow of my setup.
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
rmvlt1100 is offline   Reply With Quote
