Old 03-30-2012, 09:46 AM   #1
Magic0nas
Magic0nas's Avatar
Smile Brake Power Booster swap ???!!!!
Hi,
i just wanna know if i can swap my suburban 1990 1500 brake power booster
to my c20 1979 silverado truck
Can i make the swap with no problems???
Thanx Guys
Magic0nas is offline   Reply With Quote
Old 03-30-2012, 11:11 AM   #2
C15_Sierra
C15_Sierra's Avatar
Re: Brake Power Booster swap ???!!!!
When I did my power brake swap on my '80, I used the booster and m/c from an '84 (had initially purchased a used booster for an '84 and a new m/c - booster ended up being bad so I swapped it out w/ a re-man one, still for an '84
RockAuto lists the part numbers by brake code (i.e. JB5, etc.) so I kept the brake codes consistent (for me, it was the lightest-duty power brake option, or JB3, that I was going for) across the different years.
Looks like 3/4 ton brakes are compatible with 1/2 ton truck and Suburban brake options (JB5) so you should be able to do the swap w/ no problem.
Good luck
-Steve
1980 GMC C15 Sierra LWB
Dark Carmine Red/Carmine Int
Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011)
Now: 5.3/4L60E, 2.73 12-bolt open rear
C15_Sierra is offline   Reply With Quote
Old 03-30-2012, 11:17 AM   #3
Keith Seymore
Keith Seymore's Avatar
Agree.
Looks like it depends on the specific brake RPO on the 3/4 ton.
Here are the brake system release charts for '87; according to these the 1/2 ton JB5 system and the 3/4 ton JB6 use the same booster, by part number 18010581 / "FD":
Chevrolet Flint Assembly
1979-1986
1986 - 2019
