Fuel tank connection leaking
I still have the tank behind my seat in my '65. Whenever I fill up, fuel will leak out of the compression fitting where the hard fuel line connects to the sending unit on the tank. Could Teflon tape/liquid Teflon possibly remedy this? And yes, it is good and tight.
Posted via Mobile Device |
Re: Fuel tank connection leaking
Try it, all it could do is fail...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
I would try it first, then probably replace the fitting on the line 2nd.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Compression fitting is key word here...fix it ...not with trying to patch with teflon ...my 2 cents
