Radiator and fan shroud question
Having problems with motor wanting to get hot while driving. Will a 73-87 fan shroud and radiator work in a 67 c10
Posted via Mobile Device |
Junior Member
Re: Radiator and fan shroud question
I don't know about the radiator, but we put a '73 BB fan shroud in my '71 when we put the '73 454 in it.
It did require a little modification of the shroud to get it to clear the crankshaft pulley and the alternator on the passenger side.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
BLACK SATIN
![]() Join Date: Jan 2009
Also, from what i've read, the fan blades need to be half in & half out of the end of the shroud.
Do you have the 6 cyl shroud which is just on top?
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new 67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering 85 C10 Silverado- 305ci |
Junior Member
I have always heard the same thing, that the fan blades need to be half in and half out of shroud opening.
425hp409
![]() Join Date: Oct 2008
I have fixed many an overheating problems by repositioning the fan at about half in and half out of the shroud. This allows the fan to pull all the air through the fan shroud which is through the radiator, which cools the engine better. If the fan is too far in the shroud it will cabotage the air and if it is too far out of the shroud it will pull some of the air from outside of the shroud.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Oldsmobile 442, all original |
What modifications have been made? When does it overheat?
A stock setup shouldn't need anything special. If it's overheating, something is likely broken.
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. |
| Bookmarks |
