Old 03-30-2012, 10:58 PM   #1
ScottH
ScottH's Avatar
Need the compression fitting for oil pressure line
I want to hook up the factory oil pressure gauge but need the fitting on the gauge end. Does anyone have a proper compression fitting lying around?
Scott
1963 C10 swb fleetside
1966 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 03-30-2012, 11:01 PM   #2
teeitup
Just like to part out trucks!!
teeitup's Avatar
Re: Need the compression fitting for oil pressure line
Scott, I have the complete lines out there, wouldn't have to flare the end of line to put on the fitting?
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 03-30-2012, 11:45 PM   #3
ScottH
ScottH's Avatar
Randy, I dont think so, they r a compression fitting.
I already have the line run so just need one fitting that will work with stock gauge.
Scott
Old 03-31-2012, 02:21 AM   #4
WIDESIDE72
WIDESIDE72's Avatar
I have a gauge cluster that someone clipped the line on with a pair of side cutters about 4" from the gauge. If you send me your address, I will send it to you.
WIDESIDE72 is offline   Reply With Quote
Old 03-31-2012, 07:28 AM   #5
GMC AMI
GMC AMI's Avatar
Wink Re: Need the compression fitting for oil pressure line
Scott
I have a couple here if you do not find one. Darn what's it worth to you?
Would free be out of line?
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 03-31-2012, 09:28 AM   #6
CUSTOM/10
CUSTOM/10's Avatar
I don't believe you can re-use the old fittings, they get compressed when you tighten them in. I have about 10 brand new fittings that I bought years ago.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 03-31-2012, 09:41 AM   #7
tooter
tooter's Avatar
I have the line from gauge through firewall to other fitting you can have, Just shipping..
tooter is offline   Reply With Quote
Old 03-31-2012, 09:42 AM   #8
GMC AMI
GMC AMI's Avatar
Gary
You can if the whole line is included. I have reused the whole line with both used end fittings before with no leaks. Which was what I would have sent if the guy wants it. Send him a free one and I will save mine.
Old 03-31-2012, 10:26 PM   #9
ScottH
ScottH's Avatar
Thanks to everyone who offered to help, much appreciated.
PM sent to Custom/10
Old 04-01-2012, 08:14 AM   #10
CUSTOM/10
CUSTOM/10's Avatar
Your right you can re-use the whole line ! Just can't remove the fitting and re-use it.
Gary
72 SWB 4x4
My 72 SWB Build
