03-31-2012, 01:44 PM | #1 |
Radiator brackets?
I have a 72 c10 with 350. I got a new 4 row radiator and didn't think about my stock brackets not being large enough, stock rad was a 2 row. My question is what trucks used the bigger brackets stock, so I can go search the junk yard. I found some online and they seemed very expensive. Does anybody have any laying around they wanna sell? Thanks
Posted via Mobile Device |
04-02-2012, 09:29 PM | #2 |
Restoration Virgin!
Re: Radiator brackets?
You'll need the upper and lower brackets....post a want to buy (WTB) thread over in the parts forum...I'm pretty sure someone will have them and be able to help ya out
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
04-02-2012, 09:41 PM | #3 |
And if you go to the salvage yard bring a sharp flat head and hammer to get the bottom brackets out because they have rivets holding them. I learnd the hard way.
04-03-2012, 12:50 AM | #4 |
I need a complete set of these brackets too..
Will the brackets from a square body work? Upper or lower? |
04-03-2012, 09:21 AM | #5 |
I am a Referee of life.
I don't know about the SB brackets but most BB vendors carry a bracket/cushion set.It's easy to install but you do have to clearance the bottom of the rad support.Took me about 10 min with a hacksaw and channel locks.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
04-03-2012, 12:24 PM | #6 |
What did you guys do to keep the lower ones in place?
04-03-2012, 02:20 PM | #7 |
look in my thread on parts board, I have several upper 2 and 4 row, sand blasted and painted, under 67-68 emblems & misc parts
04-03-2012, 02:22 PM | #8 |
I used a couple bolts.The rubber cushions are relieved so they don't interfere with them seating in the mounts.The upper mounts move to the outside holes set up for them from the factory.
04-03-2012, 02:27 PM | #9 |
I found it was hard to put bolts in because the frame was in the way. I ended up just welding them in there and had one riveted in but would like to rivet the other as well. Just wanted to make sure it was secured and wouldnt move. My welding sucks and aint pretty but just as long as it sticks there.
